valve cover torque value
Old Apr 21, 2006 | 06:07 PM
earlymustang's Avatar
earlymustang
Default valve cover torque value
I'm replacing my valve cover bolts and gaskets. The manual doesn't appear to specify a bolt pattern to tighten? Also, the only torque value I could find in the manual was for "valve rocker arm cover" 3-5. Is this the same as valve covers?
Thanks
Old Apr 21, 2006 | 06:31 PM
69mach1377's Avatar
69mach1377
Default RE: valve cover torque value
Yes, but the real value is somewhere between; not enough to seal and so much that you ruin the cover.
Old Apr 21, 2006 | 06:34 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yep, that's one and the same. Sometimes it is referred to as the rocker cover. I would gently snug each bolt, then working from the center, tighten each about a half turn until you finally reach the torque. It ain't much though. If you squeeze the gaskets too much they will leak over time.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
guitarman376
Sep 30, 2015 05:54 PM
