Is this going to be a problem?
Old Apr 21, 2006 | 11:29 PM
popper's Avatar
popper
Default Is this going to be a problem?
Not much clearance between fuel filter and new sway bar.
[IMG]local://upfiles/30705/4D1A1995EBCC40D695758973E2714F15.jpg[/IMG]
Old Apr 22, 2006 | 12:11 AM
Rorin67's Avatar
Rorin67
Default RE: Is this going to be a problem?
Ouch - that's tight! [:@]
I think your thinking is correct - between the vibrations of the motor, and the travel of the sway bar with the suspension, you may indeed run into some MAJOR problems. Just piece of mind would sure would be worth the cost of one of those filter/pump relocation kits, or maybe even an electrical pump.
Old Apr 22, 2006 | 12:22 AM
popper's Avatar
popper
ORIGINAL: Rorin67
How does the filter/pump relocation work? And do you know where I could get one?
Old Apr 22, 2006 | 12:27 AM
Rorin67's Avatar
Rorin67
Now that I think about it some more, I think the relocation kit is only for an oil filter. You may need to just switch to an all-out electrical fuel pump and close off that fuel pump area on the block. So why is there so little clearance - haven't really seen this prob before...?
Old Apr 22, 2006 | 12:33 AM
1965MustangFastback's Avatar
1965MustangFastback
I think you might get away with using a 66 style pump, it dosent have the hanging filter on it.
Old Apr 22, 2006 | 12:43 AM
popper's Avatar
popper
The filter can is larger than the one I replaced. I wonder if they sold me the wrong one.
Where is the filter on the '66 style?
Old Apr 22, 2006 | 12:54 AM
1965MustangFastback
The filter is inline, at the top of the carb!
Old Apr 22, 2006 | 12:57 AM
1965MustangFastback
Heres one on ebay thats a 66 style! Not sure why its a red color though? The color is wrong
http://cgi.ebay.com/ebaymotors/Musta...QQcmdZViewItem
Old Apr 22, 2006 | 01:33 AM
popper's Avatar
popper
thanks for the help!
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
