68 Backup Lights not working
Old Apr 22, 2006 | 07:03 PM
teemoe's Avatar
teemoe
Default 68 Backup Lights not working
Trying to get my 68 Mustang back up lights working. They were pretty old and nearly falling apart so I rebuilt them by removing the lamp plug from the housing and installing new ones from a local parts store (the originals were 2 contact type and I replaced them with 2 contact type). This did not solve the problem of getting them to work. They are wired into 2 plugs located near the brake lights inside the trunk. I tested to see if it was my rebuild job that was causing the problem but it seems ok because when I put a postive and negative 12 V to the 2 wires, the light comes on. Are the 2 wires supposed to both be powered (and rely on the light itself to be a ground)? If the problem is not there, it must be at the switch, right? In the 68, there is a swtich mounted to the transmission that has 4 wires and runs up into the back of the dash. The swtich is actually a collar that turns as the transmission changes (not a swtich that the linkage pushes on). Is there supposed to be another swtich? Can someone offer some advice?
Old Apr 22, 2006 | 07:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 68 Backup Lights not working
I can't tell you for sure about the 68 backup light switch, but on my 65, it is located at the rear of the tranny and the shifter linkage operates it. When I put it in reverse (manual) the switch activates the lights. I suggest that if you also have that same kind of switch, that you take it out and test it. If it is inoperative, then just simply replace it.
djbigskrilla
Sep 20, 2022 01:04 AM
movielover40
Aug 27, 2015 10:13 PM
bigdaddy51200
Aug 19, 2015 05:09 AM
jjwinel78
Aug 17, 2015 03:34 PM
philster0306
Aug 10, 2015 11:33 AM
