sway bar installation problem
Old Apr 25, 2006 | 09:34 PM
Frank Bullitt's Avatar
Frank Bullitt
Default sway bar installation problem
I just got a new Addco 1" front swaybar for my 1968 Cougar (basically same as a mustang). The previous owner removed the original sway bar for drag racing. Also there are new lower control arms on the car too.
It looks like the bushings do not fit properly in the hole in the control arm, they are loose and not properly seated. Looks like there should be a part called a "seat" for the bushing to properly seat. I see this part (3042) in the 1968 Cougar shop manual on page 3-19, but not on my control arms. The instructions with the sway bar says that some of the hardware from the original must be used. I assume that this is one of those parts along with the bolts/nuts for the brackets.
I have looked online and cannot find this "seat" anywhere at mustangsplus etc.
Does anybody know where I can obtain these "seats"
Also for the bracket bolts/nuts that are missing, I could just get them at a hardware store. Any particular grade bolt that I should be using on these ?
Thanks
Old Apr 25, 2006 | 10:37 PM
slickman's Avatar
slickman
Default RE: sway bar installation problem
If you could post a pic, it would help.
ORIGINAL: Frank Bullitt
Thanks
Old Apr 26, 2006 | 02:00 AM
Scott H.'s Avatar
Scott H.
I haven't seen the seat washers sold seperately, Although a bushing kit should come with everything including the bolts.
Grade 8 bolts and Nylocks are what you want in the nut and bolt department. (IIRC) Prothane has a sway bar bushing kit that comes with everything you need, except the bolts and nuts for the two sway bar bushing brackets. I'd place a call to a reliable source, or maybe someone here has bought the bushing kit and can help you out.
BTW: Good catch! Nice to see someone pay attention to details.
squishbang
Sep 7, 2015 07:57 PM
cedarmn
Aug 28, 2015 09:51 PM
Mobiusone stang
Aug 24, 2015 04:08 PM
cedarmn
Aug 20, 2015 03:14 PM
01moostanggt
Aug 17, 2015 01:22 PM
