Valve Adjustment
Old Apr 29, 2006 | 03:53 PM
badazz68stang's Avatar
badazz68stang
Default Valve Adjustment
What kind of skill and time is needed to adjust the valves for my 289?
Old Apr 29, 2006 | 04:42 PM
chrumck's Avatar
chrumck
Default RE: Valve Adjustment
I'd say it's not very complicated, but you need to know exactly what you have to do. Messing this up can be painful. Try to get some workshop manual, I'd adwise detroit iron for a good example.
Old Apr 29, 2006 | 07:15 PM
ideal_mustangs's Avatar
ideal_mustangs
If they're hydraulic, theres not much to it. Just be sure to get them tight, but you just have to do it when the valve is closed.
Old Apr 29, 2006 | 07:22 PM
67coupe's Avatar
67coupe
If they are hydraulic you need to rotate the engine untill the valve is off the cam lobe. Loosen the valve and then slowly tighten it as you kepp checking the clearance between the valve stem and rocker. As soon as they make contact with no play tighten another 3/4 of a turn. Repeat same proceedure 15 more times.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
