Engine Question...
Old May 4, 2006 | 02:57 PM
PONYBOY65's Avatar
PONYBOY65
Default Engine Question...
Hi guys, every time i turn my engine on in the morning i have to give her a little gas to get her going...Do you guys do the same or could it possibly be my carburator? Thankyou
Old May 4, 2006 | 03:07 PM
badazz68stang's Avatar
badazz68stang
Default RE: Engine Question...
Most carbureted motors need a lil squirt of gas on first start up to run. Unlike the EFI you cant jus expect to barely bump the starter and it start right up and purr every mornin.
Old May 4, 2006 | 03:12 PM
tyler72's Avatar
tyler72
No, its fine. Crabs tend to do that. Even a brand new Holley or Edelbrock will require this because the gas will evaporate out of the in take if the car sits a while.
Old May 4, 2006 | 03:20 PM
PONYBOY65's Avatar
PONYBOY65
WOW that was fast!...Im glad you guys got that clear for me...Thanks for info
Old May 4, 2006 | 05:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
You will learn just how many times you need to pump the gas pedal for the best start. Mine takes two full pumps, then I still have to pump it a few more times after the engine starts to get it running smooth without dying.
Old May 4, 2006 | 05:26 PM
ideal_mustangs's Avatar
ideal_mustangs
The owners manual even says to pump it a few times and hold it at a certain position to get it started.
Old May 4, 2006 | 06:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: ideal_mustangs
Yeah, but you know good and well that all carbureted engines have their own individual quirks. It's a matter of trial and error.
Old May 4, 2006 | 08:47 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: badazz68stang
mostinjected engines ur not supposed to press the accel when starting!
Old May 4, 2006 | 09:00 PM
Fastback Guy's Avatar
Fastback Guy
Glen,
As you said, I think every car is different. I've got a Holley 4B on mine and she requires 3 full pumps and will start EVERY time. Then give her a little gas and she's ready to go.
Old May 4, 2006 | 09:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Fastback Guy
Glen,
There ya go....as I said, they are all different. That's what makes them so special, and why most of us Mustangers won't let others drive our cars because of the quirks.
