Charging system
Old May 4, 2006 | 03:26 PM
SHAKE IT's Avatar
SHAKE IT
Default Charging system
1970...... Will driving home last night...head lights started going dim and things died as pulling into drive. Rplaced alternator, but still not charging (12.44 volts going to battery) Now....hind sight being as keen as it is.....I will replace the cheaper portion of the charging system. (The Voltage Regulator) although it looks in good shape. I don't believe there is any other possibility is there? All wires look good and no loose connections. Plus it ran good before being stored.
Old May 4, 2006 | 03:54 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Charging system
Could be the battery. I think the Autozone can load test that for you before you buy it.
Old May 4, 2006 | 03:55 PM
SHAKE IT's Avatar
SHAKE IT
Battery seems good....charged it last night and drove to work this AM.
Old May 4, 2006 | 05:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
The best advice I think I have ever received by a mechanic was to automatically replace the Voltage Regulator when replacing the Alternator. Give that a try.
Old May 5, 2006 | 09:31 AM
SHAKE IT's Avatar
SHAKE IT
Voltage regulator was the problem 14.05 volts now
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
