Vacuum lines?
Old May 8, 2006 | 01:42 AM
68Midnight's Avatar
68Midnight
Default Vacuum lines?
Are these vacuum lines? Where do the other ends go ...they are just hanging out in my engine compartment.....along with another hard line coming from my carb just aiming torwards the ground....connects to nothing.
http://i26.photobucket.com/albums/c1...24f3e2b42a.jpg
Old May 8, 2006 | 01:45 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Vacuum lines?
do u have the swing away steering column?
Old May 8, 2006 | 01:51 AM
68Midnight's Avatar
68Midnight
What is that?
Old May 8, 2006 | 02:02 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
it swings away when u open the drivers door! kinda like tilt but to the inside of the car! i believe that the swing away car arealso tilt cars but dont quote me on that im not up to snuff on the 67-68 cars as i am the 65-66/71-73
Old May 8, 2006 | 02:03 AM
68Midnight's Avatar
68Midnight
so what your saying is that the actual steering coulm physicaly moves while opening the door...if thats what your saying...then no.....what would that have to do with those two lines anyways?
Old May 8, 2006 | 02:07 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
its operated on vac! na dwould be on that side of the car? and i believe there would be two door jamb switches the reg dome light one and then the swing away but i not sure though?
Old May 8, 2006 | 02:09 AM
68Midnight's Avatar
68Midnight
riiiiight...maybe i should forget about them
Old May 8, 2006 | 02:13 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
if the car runs fine i wouldnt worry about but its a good idea to replace all the vacum lines and caps to make for a leak free engine that has a smooth idle!
Old May 8, 2006 | 02:16 AM
68Midnight's Avatar
68Midnight
You know anything about the carb line that goes to nothing? Its a copper/metal line. goes the the rich/lean ****.
Old May 8, 2006 | 02:19 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
probably the line that goes to the manifold for the choke correct?
