is the 4 core better?
Old May 8, 2006 | 03:36 PM
shikoz's Avatar
shikoz
Default is the 4 core better?
is the 4 core radiator better, or necessary for my '66 289 (not very high performance)? i live in southern cal and stop and go driving is a regular occurance- at times the engine temp, according to the gauge, goes well over the half mark to about the 3/4 mark in these sorts of conditions. maybe a 4 core is the way to go? i'm curious if those that have made the switch from 3 to 4 core have had noticable differences, both positive/negative.
thanks
Old May 8, 2006 | 03:49 PM
usmcdevilmp's Avatar
usmcdevilmp
Default RE: is the 4 core better?
the 4 core radiator isnt necessary. it does look cool. i live in so cal too and i understand. just get a electric fan if your worried. im going with the flex a lite #150.
Old May 8, 2006 | 04:23 PM
Fastback Guy's Avatar
Fastback Guy
As most know, overheating is a major problem with early Mustangs. I'd get the biggest radiator I could just as a preventative measure if nothing else.
Old May 8, 2006 | 04:30 PM
Soaring's Avatar
Soaring
I ♥ Acer
I have the 4 core in mine. However, the cores are a little further apart and the fins are a little larger on the 3 row. At any rate, if you have a 2 row, then you need to step up to either a 3 or 4 row.
Gun Jam
Oct 4, 2015 12:10 AM
steelers743
Aug 31, 2015 07:16 AM
Calizic
Aug 28, 2015 01:46 PM
DrunknRuckus
Aug 23, 2015 10:05 AM
