H pipe VS. X pipe
Old May 9, 2006 | 08:20 PM
Smothers's Avatar
Smothers
Default H pipe VS. X pipe
While I am changing out my mufflers, I was thinking about adding a H or X pipe to my exhaust system and was wondering what some of you think about the H & X pipes; which one is the way to go?
BTW the application is for a built 289 w/headers.
Old May 9, 2006 | 08:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: H pipe VS. X pipe
The X will give you a better air flow. And, that is what you are looking for. However, there is a slight difference in the sound of the two. I have the H on my 65 289 for the deeper sound with my ravin mufflers, but if you are into serious horsepower, the X pipes are definitely your better choice.
Old May 9, 2006 | 08:32 PM
SuperHoss's Avatar
SuperHoss
X-pipe is the better as far as performance (neither H or X give a big change in street vehicles, only a small one). I think ground clearence and room around the transmission are the big issues when using an X pipe because the two exhaust pipes run together at one point.
Old May 9, 2006 | 11:40 PM
JBradley500's Avatar
JBradley500
IMO---h pipe sound outweighs the x pipes hp #'s...again, IMO.
Old May 10, 2006 | 10:31 AM
jrrhd73must's Avatar
jrrhd73must
X pipe is like 7-10Hp more than the H pipe. Go X if you are going to change.
Old May 10, 2006 | 01:34 PM
Fastback Guy's Avatar
Fastback Guy
The X will give you a MINOR HP + over the H but the H sounds a little deeper. I went with the H on my car because it'll never be raced so the 1-2 HP that the X would give wasn't enough to matter.
Oh, and Glen, don't rear this next statement. . . . . I have the Flowmaster Series 40 with the H and it sounds GREAT!!! LOL
Old May 16, 2006 | 03:30 AM
Smothers's Avatar
Smothers
ORIGINAL: jrrhd73must
7-10Hp more than the H pipe, for a total of approximately what total Hp increase over just headers and dual exhaust?
Old May 16, 2006 | 01:23 PM
CompYellow69's Avatar
CompYellow69
In theory wouldnt seperate dual exhaust be better because there would be no additional back pressure?
Explain why if I am wrong..
Sep 24, 2015 09:18 PM
trashxtrash
Sep 20, 2015 10:49 PM
JT76
Sep 20, 2015 11:32 AM
BrantleyS550
Sep 14, 2015 04:18 PM
wawagner82
Sep 13, 2015 09:02 AM
