Filter Fitment
Old May 11, 2006 | 01:27 AM
daver's Avatar
daver
Default Filter Fitment
So I am almost done the 351W swap on my 68 coupe. I have one problem though. I have a 71 351W with a 2 Barrel carb and the spacer that came from the factory. I need to find a filter housing that will fit under the hood. I could not find a 2 Barrel application in the FAQ section. Is it possible for me to mill some off that spacer without it affecting the heat? I have the cast iron intake on it so it will hold heat alot longer then an aluminum unit. Any help is appreciated.
-Dave
Old May 11, 2006 | 02:50 AM
Scott H.'s Avatar
Scott H.
Default RE: Filter Fitment
How about exchanging the stock spacer with a phenolic one that is thinner. It would block heat and allow for more room. You could basically make the thing yourself. It's about like working with wood.
Just a thought.
They also make what is called a "drop base" air filter base. It sits lower than the the top of the carb body.
Any chance you can change the mounts to get the motor a little lower in the engine compartment?
Good luck,
Scott
Old May 11, 2006 | 04:36 PM
daver's Avatar
daver
Where would you find a "Drop Base" air cleaner??
Old May 11, 2006 | 05:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
In the old days, guys would just cut a spacer out of 3/4 inch plywood. Worked great.
If the 65 engine mounts will hook up to the 351, they are lower than the 66 I know, and probably lower than the 68 too.
Oct 26, 2015 05:01 PM
piotrek53
Oct 13, 2015 06:54 PM
svfetter
Oct 5, 2015 11:39 AM
Demodulates
Sep 18, 2015 11:14 AM
SteelerNation82
Sep 16, 2015 07:11 AM
