New Flamethrowers
wusup to everyone i havent been on mustang forums in a long time, well anyways i just finished putting in my flamethrowers and i have a little problem.....im driving down the street and engage the flames they shoot out but my whole car,.... i cant explain it it just pauses im running 3 coils one in the engine and one on each exaust.someone told me i need a new silenoid but i have dought can anyone help me!!!!!
Hello,
I not an expert by any means but I have some ideas I'll throw down. First one-check wiring for loose connections, loose connections will draw more amps. Two-run one coil in the backside but I'm not sure if thats even feasable. Three- bump up to a larger amperage alternator I have a feeling that the alternator is not able to keep up with three coils. Four- get a larger amp battery for more reserve power. And last-If you are wired to cut power from the engines coil to put raw fuel into the exhaust the timer may not be set right. Good luck!!!
Did you read the instructions? The way the flame throwers work is to cut off ignition to your engine, so that you have enough raw fuel in the pipes. This is normal for this kit. Its not an afterburner.
i believe this kit burns off the excess fuel not burned by the engine.
http://www.flamethrowers.com.au/home.html
go to the FAQs for info about it.
