Draining Battery
Old May 14, 2006 | 08:37 PM
MidNite27's Avatar
MidNite27
Default Draining Battery
Just a quick question. In my Mustang the battery keeps dying, its a new battery. I think the problem is the Cassette player inside, the digital clock is always on, keys in the car, out of the car w/e the digital clock is always on. Could this be draining my battery?
Old May 14, 2006 | 08:49 PM
Gun Jam's Avatar
Gun Jam
Default RE: Draining Battery
If its just the clock no. it could be an accessory light that is staying on inside the glove box maybe. Or the cd player is using more than just the clock.
How long does it take the battery to die?
Use a multi meter set it to dc current and hook it inline with say the positive batter lead (NOT ACROSS + -) and check current drain with car off.
Measure voltage of batter with car off Then measure voltage with car running it should be more volts say 13.5 to 14.5 volts with the engine running at 1,500+ rpm and near 12 with engine off. If it’s the same voltage with engine on vs off then the alternator is bad.
Gun
Old May 14, 2006 | 08:58 PM
Soaring's Avatar
Soaring
I ♥ Acer
Gun is right on. Take the alternator to a parts place and have it checked. If it is bad, then replace the Voltage Regulartor too. It could also just be a bad VR, so if the alternator checks out, replace the VR. Those VR connection also get crud on them, and stop working properly.
Old May 14, 2006 | 09:00 PM
MidNite27's Avatar
MidNite27
I think the Cassette player may be using more than just the clock, it sounds like its trying to use the radio as well. None the less i know the car has wiring problems. I mean if the keys are in the car i can turn on the heater fan it turns on the starter and my car starts up. And i dont think the car should be able to start up by flipping the heater fan lol.
Anyways i will try to use the meter. It takes about 3 days of the car sitting to die.
Old May 14, 2006 | 09:29 PM
usmcdevilmp's Avatar
usmcdevilmp
ORIGINAL: MidNite27
WTF!?!?!?!?
Old May 14, 2006 | 09:40 PM
MidNite27's Avatar
MidNite27
...the heater fan switch must be attatched to the starter switch, thats wtf. lol its wired wrong.
Old May 14, 2006 | 10:00 PM
Gun Jam's Avatar
Gun Jam
Sounds like a fire hazard to me.. If that were my ride I would make a summer project out of it and redo most of the wiring using some type aftermarket wiring harness.
Gun
Old May 14, 2006 | 10:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Gun Jam
Gun
I agree.....that is FUBAR wiring.
Old May 14, 2006 | 10:23 PM
MidNite27's Avatar
MidNite27
It has a new wiring harness on it. Something must have got switched up during the install.
Old May 14, 2006 | 10:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: MidNite27
most likely. Go back and trace it with the wiring harness instructions.
