boss 302 4v heads
Old May 15, 2006 | 02:45 AM
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
Default boss 302 4v heads
can someone tell me a little bit of info about these heads? whats special about them?
Old May 15, 2006 | 03:08 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: boss 302 4v heads
fit on a 302 4v ports to large for street use but the 2v heads are great street performers they are already modified to fit on a 302 block but edelbrock has some new heads that feature the 4v combustion chamber with the 2v ports for a perfect street head! and they come modified for use on a 302! www.351cleveland.net if u want more info!
Old May 15, 2006 | 03:13 AM
FiveLiterRiceEater
ok so the 4v heads are the ones that are crap for low end torque? i think i asked someone this once and forgot about it
Old May 15, 2006 | 03:16 AM
FiveLiterRiceEater
and say i had a set of 2v heads off a cleavland, what all would need to be done to make them fit a 302?
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah the best cleve head that ford made was the (sometimes referred to as a 3v?) aussie head setup like i metioned above 4v chambers and 2v ports www.ausford.com they sell them and block other aftermarket heads etc!! the 2v is the stump pulling head
Old May 15, 2006 | 04:03 AM
Shifty101Easy's Avatar
Shifty101Easy
the idea of the boss was high rpms and top end speed i believe....thats why the low end torque isnt too impressive......
Old May 15, 2006 | 11:13 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
drill water passages and get a custom intake and check ur piston to valve clearence! bush performance makes an intake for the conversion and i believe edelbrock is supposed to make one also soon!
69Volunteer
Sep 30, 2015 10:39 AM
ryland
Sep 13, 2015 12:35 PM
WDScott
Aug 17, 2015 06:38 AM
ccwebb
Aug 11, 2015 06:47 PM
mustangfan305
Aug 7, 2015 11:09 AM
