rally pack clock
Old May 17, 2006 | 08:55 PM
Smothers's Avatar
Smothers
Default rally pack clock
The clock on my rally pack works, but does not keep time well (its fast). Does anyone know of a place the fixes them or maybe sells just the clock?
Old May 17, 2006 | 09:49 PM
skiprCH's Avatar
skiprCH
Default RE: rally pack clock
HI,
Check out these guys. http://www.clockwks.com/CLOCKWORKS/Servicex.html They put in an orginal movement in my rally pac for around 100 bucks. They can do a quartz movement too for less money but you will lose concourse points because the sweep of the second hand does not tic like the old ones did. If that concerns you or just what to keep it orginal.
Walt
Old May 18, 2006 | 12:40 AM
ELT's Avatar
ELT
Had 2 rally pacs and they both ran fast. Supposedly there is a regulator in there. The clock is supposed to adjust its speed in the direction in which you correct the time. Worked in my 65. No luck so far in my 66. Might reset it backwards 12 hours to see if that works. If not, I would much rather have the original clock that runs a little fast or get it fixed as opposed to a new quartz gizmo. I like my pony as original as possible. I look at my watch if I want to know the time.
Old May 18, 2006 | 02:24 AM
289FB's Avatar
289FB
Let the clock be fast but keep it original
Old May 18, 2006 | 02:56 AM
Smothers's Avatar
Smothers
ORIGINAL: skiprCH
HI,
Walt
Thanks for the info and link, I will check them out. I think I would rather pay the 100 bucks and keep it original.
Old May 18, 2006 | 02:57 AM
Smothers's Avatar
Smothers
ORIGINAL: ELT
Man that is some good info. I will give it a try.
Granatelli Sales
Mar 25, 2016 08:01 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Sixer4Life
Sep 28, 2015 07:05 AM
Sep 25, 2015 09:06 AM
