Anti Freeze????
Hi guys im finally done repairing my chaincover, and waterpump. I have re-installed it all today with new gaskets all around...now im having an issue on anti freeze...The old man who repaired my radiator says anti-freeze will screw up my coolent system and eventually engine because of the acids inside of the liquid...i live in sunny southern california were its never really cold, thats why the old man says i dont need it...then i have other people saying hes nuts and i should run 50/50...what do you guys think?..what do you guys use in your pony's?, and what do you guy's recommend?..thanks
ORIGINAL: PONYBOY65
30/70 sounds very good...i think im gonna go with that mixture...any other suggestions...thanks guys
ORIGINAL: randy78045
also use distilled water... not to be confused with filtered drinking water...
and ponyboy, you can check you local parts store for the filter, if not here's a link for Gano radiator filters
That is why they call it "COOLANT", and not "Anti-Freeze". Glycol (ingredient) is used in hospitals and all kinds of mechanical heating and cooling systems. It helps disipate(sp) heat as well as freeze protection. So, with only water, distilled, filtered, or tap, what do you think it will do...not rust? Don't be stupid! (Nothing personal) Now, however, there are some aluminum engines, motorcycles in particular, that need a special kind of coolant with additives to prevent corroding. My wife has a Honda (and it's ok next to my Harley cause its a goodin!) and it (of coarse, mfg) recomends certain COOLANT.
