Need to replace a steering wheel. Help!!
Old May 30, 2006 | 11:32 AM
Shelbyville's Avatar
Shelbyville
Default Need to replace a steering wheel. Help!!
I have a 67 fastback with a 68 steering wheel. Although the padded wheel looks good, I would prefer the original look of the 67 wheel. How much work is involved in removing this wheel? I can't find any procedure on how to do it. If someone knows of something, please point me to it. When I removed the emblem from the front of the pad, there appears to be just a single recessed bolt holding it on. Do I really need a puller??
Old May 30, 2006 | 11:44 AM
67coupe's Avatar
67coupe
Default RE: Need to replace a steering wheel. Help!!
A puller is the best way not to damage the shaft. Some parts stores loan tools, but it isn't an expensive tool to buy. The other method is to back the nut off flush with the shaft. Use pressure from your knee under the wheel and pull on the top at the same time while striking the nut with a hammer. It should pop loose. Be careful not to flare the end of the shaft.
Old May 30, 2006 | 02:00 PM
Shelbyville
Thanks. You are correct about the loaning of tools by auto parts stores. I found that Autozone does loan out tools like this, free!! If anyone else has had personal experience removing a 68 steering wheel, feel free to chime in.
Old May 30, 2006 | 03:08 PM
Shifty101Easy's Avatar
Shifty101Easy
i did, u prob wont wanna do it that way though.
i took off the pad, and theres the big nut....i took off the little horn thing, then got a wrench to take off the nut, i took a little league baseball bat and pried the wheel off after budging it a little bit by tapping it firmly with the bat.....very firmly, not quite violently though. It came right off after that.
Old May 30, 2006 | 03:33 PM
Shelbyville
Thanks. Are you saying do not use the wheel puller? I am not sure if I have a bat So it was just the single bolt and it comes off.
Curious why you removed the horn ring first.
Old May 30, 2006 | 07:15 PM
Shifty101Easy
well, on my wheel, all u had to do was twist it of fand it came off....and that allowed me clearance to get to that big nut that holds the wheel on........i didnt have a big enough socket so i just used a cresent wrench after taking off the horn ring.
Old May 30, 2006 | 09:22 PM
R1PPED's Avatar
R1PPED
Mine came off rather easily. in fact too easily. in fact, while i was driving.
So i'm guessing it can't be too hard to get one off...
Old May 31, 2006 | 03:35 PM
Shelbyville
R1PPED,
LOL! Thats what I am afraid of, only with the new wheel. Thats why I wanted to do it right. Thanks to everyone for their input.
carid
Jul 8, 2016 09:55 AM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
2007CalSpec
Sep 9, 2015 05:37 PM
Sep 8, 2015 11:50 AM
