Ford 8 in Vs 9in
Old Jun 1, 2006 | 02:45 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default Ford 8 in Vs 9in
i currently have the 8in on my 67 coupe and am wondering how they stand up comaperd to the 9 in is it just a good or what i am not a big racer or anything but i do like to put my foot on the pedal and drive my baby hard from time to time just to get a thrill but would there be any advantage to having the 9in over the 8in cause its mainly a daily driver but i am gunna take it from 2.75 ratio to a 3.80 but only if the axle will fit my usage cause if it don't then i will get the nine
Old Jun 1, 2006 | 03:06 AM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Ford 8 in Vs 9in
i assume you have like a 289 or something in your car....and if its a daily driver, a 8" is fine. a 9" is never a problem but isnt really needed for what you got going on.....
Old Jun 1, 2006 | 03:11 AM
Brandontyler65
I ♥ Acer
ok thats what i thought i just wanted the best for what i got and not over kill cause i don't know anything bout the 8in but i found out first hand that Dana 44 isn't good for 4WD and was wondering if i would have to change to a nine like i changed my truck to a Dana 60
Old Jun 1, 2006 | 03:44 AM
ngirg001's Avatar
ngirg001
what about an 8.8??
Old Jun 1, 2006 | 03:46 AM
Shifty101Easy
if u have the extra dough....and know how....the go for it....get posi and 3.25 or 3.50 gears while your at it....but if not....ur fine....get posi still though if possible lol
Old Jun 1, 2006 | 07:01 AM
65_2plus2's Avatar
65_2plus2
I would keep the open spool 8” as it will handle up to 300hp, and not go so steep on the gearing. Go with a 3:25 or 3:55 instead.
Going from a 2:75 to a 3:80 will drastically kill your gas mileage. An 8” rear gear from a performance company such as Auburn gear can handle up to 400hp.
Cheers…..[sm=icon_cheers.gif]
Old Jun 1, 2006 | 01:53 PM
THUMPIN455's Avatar
THUMPIN455
Agree on the ratio, 3.80 is a bit deep, I wouldnt go more than 3.55 and if its a daily driver a 2.79-3.00 would be perfect. The nice thing about an 8 or 9 is gear swaps are quick and easy. So if you wanted you could have a 3.80/4.11 pumpkin and a 2.70-3.23 gear for cruising.
An 8.8 gear swap is much more involved, and getting one under an early mustang takes more than just boltin it in
Old Jun 1, 2006 | 01:57 PM
Shifty101Easy
ORIGINAL: 65_2plus2
isnt a spool what they use for like striaght line drag racing....?? u cant even turn...its a 100% locked differential....?
Old Jun 1, 2006 | 02:30 PM
Brandontyler65
I ♥ Acer
ya i was thinkin bout it last night and the 3.55seems to be a better choice
Old Jun 1, 2006 | 02:45 PM
THUMPIN455's Avatar
THUMPIN455
a spool isnt a differential, as it it doesnt allow one wheel to turn faster or slower, yeah they are locked together. its a solid piece betwen both axles, no clutches, cones or anything. just a chunk of aluminum or steel with a ring gear mounting face, some bearing races, and axles splines. very light, very strong, and very race oriented.
