Crank Pulley
Old Jun 1, 2006 | 09:47 PM
Shifty101Easy's Avatar
Shifty101Easy
Default Crank Pulley
ok i got my dual groove underdrive crank pulley finally today and i wanna get it put on....if i take my car to kragen do i need an appt. or something or can i just take it there??? i have a alternator one too to put on.....
how much do u expect this to cost do u think????
Old Jun 1, 2006 | 10:18 PM
1965MustangFastback's Avatar
1965MustangFastback
Default RE: Crank Pulley
Why not do it yourself? Its only a few bolts for the crank and one on the alternator! You'll save yourself about $100 in labor
Old Jun 1, 2006 | 10:20 PM
Shifty101Easy
id love to do it myself but i was under the impression i need a pulley puller and all that?
Old Jun 1, 2006 | 10:59 PM
Shifty101Easy
im reading in a magazine right now u need a access to compressed air and air rachet, a pulley puller, etc etc.......i have like basic hand tools........
Old Jun 1, 2006 | 11:56 PM
paladin_1888's Avatar
paladin_1888
Just pulled the carnk pulley, timing cover and oil pan off my 65 with 351, used only hand tools and an $8.00 pulley puller, crank pulley took maybe 15 minutes.
Old Jun 2, 2006 | 12:01 AM
Shifty101Easy
can u give me a link to what crank puller to get??? i jsut wanna picture so i can go to a store and buy it......it might be too late now....i could go tomorrow probably though.
Old Jun 2, 2006 | 12:02 AM
Shifty101Easy
i need to buy a bigger socket also.....the main bolt is huge and i dont have anything that will fit it besides like a cresent wrench....which would be a jolly old time trying to use.......
Old Jun 2, 2006 | 01:16 AM
paladin_1888
Believe that take a 15/16 socket, with a 6" extension, I put the socket on it and popped it a few times with a rubber mallett, make sure car is in gear with parking brakes set, to keep from engine turning over, I used the same puller for this as I do for steeering wheel removal, one with large center bolt and three arms wwith slots, put the bolt back in the centerWITHOUT the washer, put the pulley bolts backin the arm slots of the puller and tighten the large center bolt against the ballencer bolt head, ballencer will come right off.
Old Jun 2, 2006 | 01:22 AM
paladin_1888
I may have misled you a bit, if you are only going to remove the pulleys you wont need to pull the balancer, or the puller, just take out the bolts from the pulleys and balancer, change the pulleys and put the bolts back in
Old Jun 2, 2006 | 01:26 AM
Shifty101Easy
well....my neutral safety switch is bypassed so its sorta like not making a difference i dont think????
and i can use a steering wheel pulley??
did u take off the fan and radiator hose???
and im not even 100% positive it will work with my regular 302...it said boss 302, 351 cleveland, 400M etc.......i think it will though....i hope it will......
