Those alarms are on ebay again..
ORIGINAL: Riven02
For example when a door is closed or glass is broken or when the car is started right?
i think i should just use the other one and it should work out better.
If I send you a PM can you give me a little assistance on installation, i.e. the best place to have it installed, so I can tell the guys at the body shop? I don't think I want to take this to my alarm guy
Check it out guys, Glen is happy!! https://mustangforums.com/m_1474249/...tm.htm#1474366
The remote is only about 1 1/4 by 1 1/4.. by 3/8 thick
ORIGINAL: padgecomm
How big is the remote? I have a F150 standard door lock remote, are they close. Just curious has to how big my key chain would be in my pocket with two remotes.
I bought one of these about a month ago and I can't get it to go off. I've also tried the battery and shock tower and they didnt work. Where on the radiator support did you mount yours? You have a pic? Has the sticky tape been holding up fine? How high is your sensitivity? I know the alarm works because i can set it off manually.
I also got the 2 for 1 deal and gave the other one to my friend who has a 90 something Neon. We put it by the battery and it works pretty good. I thought that it would work even better in my mustang since these old cars use a lot more sheet metal. Guess I was wrong.
