charging ?'s
Old Jun 7, 2006 | 08:27 PM
badazz68stang's Avatar
badazz68stang
Default charging ?'s
if i take the negative battery cable off while the car is running & it keeps running does this mean that my alternator is working/functioning properly?
Old Jun 7, 2006 | 08:30 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: charging ?'s
thats the redneck way of checking it will fry the alternator!
Old Jun 7, 2006 | 08:36 PM
6mustang6's Avatar
6mustang6
yeah. Scott had a conversation with me a long time ago. Never remove a cable with the car running. He said it can explode, and cause serious injury.
Old Jun 7, 2006 | 08:48 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
what can explode the battey? maybe form the spark? battery relase hydrogen gas remeber the hindenburg(sp) but it makes the alt go to full out put and it overheats it!
Old Jun 7, 2006 | 08:50 PM
6mustang6's Avatar
6mustang6
yeah, idk. That is what Scott told me, he'll be on here in alittle bit.
Old Jun 7, 2006 | 08:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
You don't want to take any of the battery cables off the battery while the engine is running. To check if the alternator is working, take it off and take it to a parts place to have it checked.
Old Jun 7, 2006 | 11:34 PM
66stangstable's Avatar
66stangstable
If you dont want to take it off you can use a voltmeter, at 2500 rpm's voltage readings should range between no less than 13.5V and no more than 15.5V. Reving it up to 2500 rpm's puts the alt. under load which is what the bench tester at an auto parts store does, so either way will work.
Old Jun 8, 2006 | 10:43 PM
Scott H.'s Avatar
Scott H.
ORIGINAL: 6mustang6
I really tried to stay away. You know, do my part to help cleanse the gene pool a bit
You two have pretty much covered it. Bad for the car, bad for your body.
Just say know...ledge.
Scott
Old Jun 8, 2006 | 10:49 PM
6mustang6's Avatar
6mustang6
HAHAHA. yep, i warned him for you Scott.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
69Volunteer
Sep 30, 2015 10:39 AM
humpbackshooter
Sep 24, 2015 10:07 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
