car shutters
Old Jun 8, 2006 | 11:50 AM
slick66stang's Avatar
slick66stang
Default car shutters
now it only shakes and studders while im in gear and stopped . does anyone know what it could be? when i put it in neutral its fine
Old Jun 8, 2006 | 01:57 PM
Clu7ch's Avatar
Clu7ch
Default RE: car shutters
just neutral or neutral and park? and what do you mean by shudders? does it just vibrate the car or the motor sounds like it's coming out. could be trans mount loose or really rough idle. i had an idle prob with a few of my cars and noticed it was a nit worse when the car was in gear than when in park or neutral.
Old Jun 8, 2006 | 02:20 PM
6mustang6's Avatar
6mustang6
Yeah, rough idle. Maybe your valves are adjusted too tight, or it's idled down too low.
Old Jun 8, 2006 | 03:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
Also, check your motor mounts to make sure one isn't broken.
Old Jun 8, 2006 | 03:23 PM
slick66stang
it stops only in neutral it sounds like its going to die and the whole car shakes. no mounts are broke or lose i think its the idle on it ill be back soon
Old Jun 8, 2006 | 04:13 PM
slick66stang
ok just got back took it to a shop they said it might be my fuel pump and fuel line going into the carb does this sound right?
Old Jun 8, 2006 | 04:15 PM
Clu7ch's Avatar
Clu7ch
i had a problem with my 89 5 speed four banger. the bushings on the trans mount mount rotted out and there was no cushion there. when ever i shifted it would fall and than pop back up. i lost quite a bit of the minimal power i didn't have to lose in the first place. down shifting became non existant after i realized what had happened. i also lost (couldn't re-install) one of my motor mounts. i don't remember which side, all i remember was it was the side all of the tq TURNED into.
Old Jun 8, 2006 | 07:16 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: slick66stang
yeah, if you're not getting proper fuel to your carb and/or from your carb to your motor, it would prolly idle purdy rough. check it out and let us know the findings.
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
HIS S-197
Aug 10, 2015 05:47 PM
