Need front hubs
Old Jun 10, 2006 | 04:36 PM
farkedup's Avatar
farkedup
Default Need front hubs
I finally got around to starting on my front disc brake swap and started down the instructions and realized that they reuse the old HUB but I have a 4 lug so I can't use mine....
Got any suggestions for a place to get this fairly quick without paying too much?
Old Jun 10, 2006 | 05:52 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Need front hubs
What are you working on? Are you reusing the spindles too? What swap kit are you using? Is your first name Al? Get it? Alfarkedup? Ha! I could not resist!
Old Jun 10, 2006 | 05:53 PM
67t5ponycoupe
And what is with that pic? Those are the longest studs I have ever seen on a front hub.
Old Jun 10, 2006 | 06:31 PM
farkedup's Avatar
farkedup
Vintage Venom front disc swap: http://vintagevenom.com/fdk.htm The long studs are because of the spacer....
Basically in their instructions it says to reuse the old hub but mine is 4lug so I just need to find a decent place to buy them and get them to me this week.
Old Jun 10, 2006 | 06:46 PM
Soaring's Avatar
Soaring
I ♥ Acer
It says you can use the brake components from SN95 Mustangs. You don't have an SN95. Send that kit back and get your money back, then order a full kit with all the parts you are going to need. That spacer hub looks just flat out dangerous to me. Trust me, you don't want 4 lugs on a disk brake swap. Read this, then email the owner to get one of the best deals on full swap kits available.
Old Jun 10, 2006 | 07:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
However, there is a way you can do it. I just dug up this MM How-To for disk brake conversion for the 6 bangers.
http://www.mustangmonthly.com/howto/17279/index.html
Old Jun 10, 2006 | 10:59 PM
farkedup's Avatar
farkedup
I'm actually trying to go 5 lug... I have a 9" rearend that I'm putting on after this is done....
Old Jun 10, 2006 | 11:07 PM
farkedup's Avatar
farkedup
I've found where it says 64-66 hubs in a couple of places: http://www.metropartsmarket.com/cata...arts-c4s1.html can't find anything about a 68
Old Jun 10, 2006 | 11:12 PM
farkedup's Avatar
farkedup
After a bit of digging this is all I've found: http://www.americanpony.com/store.mv?p=210001 I've never purchased from them before though... just been going through google
Old Jun 10, 2006 | 11:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: farkedup
Yeah, but that's just the hub. He needs the spindle. And, if you are wanting to go 5 lug anyway, why screw around with the 4 lug idea? Just contact Dennis, and do it right.
