Rough Idle
Old Jun 19, 2006 | 09:15 AM
66 coupe's Avatar
66 coupe
Default Rough Idle
Hi, I'm new to this fantastic forum and I have a question about a '66 Mustang I just bought. It has a 289 with a 2barrel carb stock setup. When the car is in gear and your foot is on the brake the idle is very rough (almost ready to stall). A mechanic told me the hose coming from the vacuum advance was going to the wrong location. The hose currently goes to the right side of the carb. According to him it should go to a fitting on the intake manifold that is on the back of the engine. The fitting he is talking about currently has two hoses going to it, one to the transmission and the other to the brake booster. Something about this doesn't sound right so I thought I'd ask the experts (you guys). Thanks!
Old Jun 19, 2006 | 09:10 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Rough Idle
Vacuum advance goes to ported vacuum on the side of the carb not to manifold vacuum.
Old Jun 20, 2006 | 10:19 PM
skiprCH's Avatar
skiprCH
I had a rough idle after some intake work. Found the line running to my tranny modulator was off. Check it.
Walt
Old Jun 20, 2006 | 10:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Take some pics of your current set up, then maybe we can help you get hooked up.
Old Jun 21, 2006 | 12:58 AM
6mustang6's Avatar
6mustang6
vacuum, valves too tight, low idle
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
MacSerio
Sep 27, 2015 01:05 PM
