roof
Old Jun 20, 2006 | 06:02 PM
guitarist88's Avatar
guitarist88
Default roof
Some Previous owner put a sunroof in my car that I am not a big fan of. I have been looking for a way to take it out. I saw that mustangunlimited.com makes a roof skin but they only make it for a fastback. Does anyone know where I could find a roof skin for a 67 coup?
thanks
michael
Old Jun 20, 2006 | 06:08 PM
EmperorOfChicken's Avatar
EmperorOfChicken
Default RE: roof
I'm not too sure I know ive seen one around somewhere on the web, could you post some pictures?
Old Jun 20, 2006 | 06:16 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: roof
A roof skin for a coupe? Never heard of such an animal. Good luck in your quest. Otherwise, invest in some sunscreen.
Old Jun 20, 2006 | 06:37 PM
guitarist88
Default RE: roof
ORIGINAL: EmperorOfChicken
http://www.mustangsunlimited.com/itemdy00.asp?T1=RP1+01
http://www.mustangsunlimited.com/itemdy00.asp?T1=RP2+01
Old Jun 20, 2006 | 06:40 PM
428coupe's Avatar
428coupe
Default RE: roof
I have the same problem on my coupe. The PO installed a sunroof and had about 2 inches of silicone all the way around it to keep it from leaking. I wanted to get rid of it at first, but I think I have decided to keep mine and replace it with one that will not leak.
Old Jun 20, 2006 | 07:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: roof
Of course...the fastback skin is relatively flat and one piece. But, the coupe has the side wings that have to attack to the rear quarter.
Old Jun 20, 2006 | 08:25 PM
guitarist88
Default RE: roof
ORIGINAL: Soaring
so could I cut the fastback roof skin and patch the sunroof or Is is shaped too differently?
michael
Old Jun 20, 2006 | 08:32 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: roof
replacement reguires a donor roof it would be easier to get the sunroof fixed if its leaking or sell the car and get a different one!
Old Jun 20, 2006 | 08:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: roof
ORIGINAL: rmodel65
True dat. Replacing a roof on a coupe is just not worth the money. Either live with it, fix the sunroof or sell it and get a real MUSTANG.
Old Jun 20, 2006 | 10:25 PM
351foxstang's Avatar
351foxstang
Default RE: roof
[quote]ORIGINAL: Soaring
ORIGINAL: rmodel65
get a real MUSTANG.
you would probably warp the crap out of the roof when trying to welding in a patch panel. there aren't any body lines or anything there to help keep the panel straight.
