Diff leak?
Old Jun 22, 2006 | 03:29 AM
baddog671's Avatar
baddog671
Default Diff leak?
I got some clear brownish liquid always hanging on the bottom of my differential and I think its leaking out the back cap thing? Im taking the whole rear end off to clean up and replace, do I need a new seal for that cap? Also, what is that called anyways? Its a 9". Can you just stick a screwdriver under it and pop it off? Thanks
Old Jun 22, 2006 | 09:52 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Diff leak?
Shoot a picture of what you are talking about. You most likely have something other than differential fluid getting to there. Maybe gas from the tank? 80-90 weight gear oil will be thick and black.
Old Jun 22, 2006 | 07:51 PM
baddog671's Avatar
baddog671
The car hasnt been driven for about 6-7 years so perhaps the seals dried up? Here are some pics from behind, under, and the front from the side. You can see dark patches where its coming from and especially the bottom. The whole thing is rusting ( which is why im dropping it to clean) except the bottom where that crap has been hanging out. No its not gasoline becuase i just replaced the gas tank with a new one and the gas lines are gone.
Old Jun 22, 2006 | 10:24 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Probably just gear lube seeping out. What is the cap you are talking about? The back of that housing is all part of the housing. The gear set comes out the front.
Old Jun 23, 2006 | 01:20 AM
baddog671's Avatar
baddog671
Oh, I thought they back section popped off but I guess not. I dont know much about the rear ends like that...Is there a bad gasket up front?
Old Jun 23, 2006 | 01:26 AM
67t5ponycoupe
A gasket and a pinion seal. That is the two places they usually leak. You have oil in some strange places though. I can't imagine that it would be coming from some where else but heck I was wrong once already today.
Old Jun 23, 2006 | 01:28 AM
baddog671's Avatar
baddog671
Lol, would those be easy to replace. Just remove the front, take it off, and put the new ones on?
Old Jun 23, 2006 | 06:06 PM
67t5ponycoupe
Not that simple. You will have to pull the axels to the get the gear set out.
Old Jun 23, 2006 | 06:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
Ooooh, Lordy. What a rusty differential. Has that thing been under water? As stated, you have some leakage in some unusual places. Maybe rust has eaten through where there are no gaskets? I guess you will find out when you get it torn down, but she does have to be yanked and torn apart and inspected.
Old Jun 23, 2006 | 06:24 PM
paladin_1888's Avatar
paladin_1888
That looked to me like a brake line leaking fulid onto the back of the diff
