Engine Swap
Old Jun 22, 2006 | 06:31 PM
DougandNate's Avatar
DougandNate
Default Engine Swap
We're considering pulling the 6 cylinder engine out of my son's 68 and putting in the 289 v8 from my 67. The 68 has a manual tranny and the 67 is an automatic. Are we nuts? Is this doable for a couple of shade tree mechanics? Any tips on where we can go to learn what we'll need to have and know to do this?
Old Jun 22, 2006 | 10:22 PM
mustanglover66's Avatar
mustanglover66
Default RE: Engine Swap
Its really no big deal you'll just have to change the bellhousing and flexplate, keeping it auto trans is the easyest way to go
Old Jun 23, 2006 | 09:26 AM
rwh129's Avatar
rwh129
good luck with your project
usually the hardest part is finding the parts but since you have everything it should be simply
Old Jun 23, 2006 | 10:52 AM
slickman's Avatar
slickman
That swap should be easy, the only thing you need to check is the pilot bearing on the crank to make sure they are the same. Worst case, you will need to install a new one to match the tranny. The other thing to keep in mind is, all you're suspension parts are for a 6 cyl so, that would need to be addressed as well.
ORIGINAL: DougandNate
Old Jun 23, 2006 | 11:55 AM
Soaring's Avatar
Soaring
I ♥ Acer
Here, do some reading. There's more to it than meets the eye.
http://www.geocities.com/a65ragtop/V.../i6_to_v8.html
Old Jun 23, 2006 | 01:08 PM
acidrain088's Avatar
acidrain088
i would replace the rear end and the brakes. the originial rear in 6 cyls cant handel mutch ahd have different gearing.
Old Jun 23, 2006 | 01:46 PM
farkedup's Avatar
farkedup
mine was originally a 6cyl and the rearend is holding up well bu the front suspension was replaced. I'm going 5 lug rims once I get the time to do the front disc brakes and finish cleaning up the 9" Rear I have
Old Jun 23, 2006 | 01:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you still have the original rear, it would be a 7.5......not a 9 inch.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
