Floor Pans
Old Jun 23, 2006 | 01:18 AM
mustanglover66's Avatar
mustanglover66
Default RE: Floor Pans
The main difference between th full floor pan and the piece together one is the piece together one do not include the trans tunnel. thats why I plan on using the full pan when I do mine. NPD has them for $495
Old Jun 23, 2006 | 01:19 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: 428coupe
I agree with soaring on the mig welder, it is a must. If you dont want to spend the dough on a new plasma cutter, you can rent one, or cut-off wheels on a grinder will do the job, only not as pretty. Plasma cutters take some practice and a steady hand also. You should replace both full length floor pans and seat risers. Make sure the car is level and on jackstands where it will not be moved during the process. It is not too hard of a job and the practice you get from the floor pans will help you when you go to replace the lower cowl panels, which are likely bad also.
plasma cutters are extremely easy to use compared to a cutting tourch if u ever used a tourch do it just like that but without all the excessive heat! and its nice cause it doesnt get all warped up and slice thru it like butter! imho it super easy just use two hands to keep it steady and make sure u dont ther frame rail off the car with the pan!
Old Jun 23, 2006 | 01:23 AM
ideal_mustangs's Avatar
ideal_mustangs
An angle grinder cuttoff wheel will do the same thing for much cheaper.
Old Jun 23, 2006 | 01:24 AM
baddog671's Avatar
baddog671
wouldnt that take awhile?
Old Jun 23, 2006 | 01:31 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah and the heat it creates will make it that much harder!
Old Jun 23, 2006 | 01:38 AM
hity645's Avatar
hity645
Yeah body work is number one right now, I was hoping the floor would be ok..just a lil surface rust.
Old Jun 23, 2006 | 01:40 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
u can pretty much draw with a plasma cutter! they are real nice when u start doing work on visible panels like quarters and fenders!
Old Jun 23, 2006 | 01:43 AM
baddog671's Avatar
baddog671
my buddy has one but ive never used it, ill have to borrow it now! How thick can they cut through?
Old Jun 23, 2006 | 01:52 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
depend on what they are rated atleast 1/2inch? or so i never tried to cut anythin thicker doing body work there are plasma cutter that they use to cut extremely thick metal in large pools of water etc. u also gotta have a fairly large compressor to go with it other wise it will not work supposedly will cut anything that will conduct electricity never tried anything else though
Old Jun 23, 2006 | 02:05 AM
baddog671's Avatar
baddog671
air compressor?
