Recently purchased 71
Old Jun 25, 2006 | 02:14 AM
alextorrenegra's Avatar
alextorrenegra
Default Recently purchased 71
Hi!
I purchased a 71 convertible just a few hours ago. While driving back home everything worked well with the exception of the headlamps. For some reason they started to go off and on randomly ((both of them at the same time). The slower I went, the faster they would go off an on. It is still random. I couldn't find any sequence, periodicity, or pattern to the issue.
Unfortunately I am new to Mustangs - What would you recommend me to check first?
Thank you!
Old Jun 25, 2006 | 03:50 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Recently purchased 71
bad headlight switch esp a problem with halogen headlight add a new switch should take care of the problem
Old Jun 25, 2006 | 10:53 AM
67Sally's Avatar
67Sally
ORIGINAL: alextorrenegra
Hi!
Thank you!
[sm=ttiwwp.gif]
Someone had to say it
Old Jun 25, 2006 | 11:23 AM
alextorrenegra
Thank you both! I will try connecting the cables directly (not going trough the switch). If it works well, then I will get the new switch.
BTW, I will post pics soon
Old Jun 25, 2006 | 11:38 AM
Soaring's Avatar
Soaring
I ♥ Acer
While you are at it, go ahead and clean all ground contacts associated with the headlight.
Old Jun 25, 2006 | 12:46 PM
THUMPIN455's Avatar
THUMPIN455
Classic Fords have some issues with corroded connections, it would be a good idea to clean and dialectric grease all the connections you can find. Also wiring a relay for the lights so all the power doesnt go through the switch will make your headlights brighter and consistent. There was a thread about it a while back on here, Glen isnt it in the FAQ? If that link isnt, it should be..
Old Jun 25, 2006 | 12:47 PM
THUMPIN455's Avatar
THUMPIN455
Almost forgot.. Welcome to the big car group.. pics would be very welcome! The 71-73 group is growing!!
Old Jun 25, 2006 | 12:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
Is this the thread you are referring to Todd?
https://mustangforums.com/m_1397235/tm.htm
Old Jun 25, 2006 | 01:00 PM
THUMPIN455's Avatar
THUMPIN455
Thats it glen.. Heres the link tht might help... So you dont have to search the thread for it http://www.midnightdsigns.com/james/headlights.htm
Old Jun 25, 2006 | 01:57 PM
Soaring's Avatar
Soaring
I ♥ Acer
Thanks goes to Charles for coming up with that link for the relay. I'll stick her in the FAQ.
69Volunteer
Sep 30, 2015 10:39 AM
RCS02v6
Sep 29, 2015 01:46 PM
kartracing87
Sep 28, 2015 11:01 PM
GLOCKer
Sep 28, 2015 07:36 AM
