underbody advice
Old Jun 25, 2006 | 11:27 PM
bradleyb's Avatar
bradleyb
Default underbody advice
I have just about got my 66 stripped down to the shell. I have powerwashed the underside of the car and there are no rust spots and it still has the red primer from the factory I think. What is everyone using for underbody coating here - I am doing the restomod and not concerned about being concours correct? Is anyone using bed liner? What about some of the rubberized products that also have some sound deadening capability? Anyone using the asphalt products like O Henry?
Also, I have some surface rust on the inside of the back floor pans - I am thinking about just taking off the surface rust and using por-15 followed up with some paint - what do you think?
Old Jun 25, 2006 | 11:43 PM
Clu7ch's Avatar
Clu7ch
Default RE: underbody advice
i personally am tossing around the idea of bed liner, rhino lining more specifically. it would work, just make sure there is nothing there at all to begin with. por-15 is excellent for minor rust spots, nothing where the rust has eaten thru, of course. the only downfall i see to the rhino lining is cost. you can also turn around and freshen up the factory primer and as long as that is in good condition, you should be on your way, with no problems.
Old Jun 25, 2006 | 11:48 PM
mlitz's Avatar
mlitz
well if you are going to use a bead liner then don use rhino stuff there is better stuff let me look around for the name.... they use in the army an stuff for building that need protecting form bombs... this stuff is indestructible
Old Jun 25, 2006 | 11:50 PM
mlitz's Avatar
mlitz
ok i found it it is called line-x
http://www.line-x.com/
Old Jun 25, 2006 | 11:51 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: mlitz
and the cost is prolly more than rhino lining!
Old Jun 26, 2006 | 03:25 AM
bradleyb's Avatar
bradleyb
Thanks guys. The line-x stuff does look cool. I am almost thinking to do the O'Henry's thing - someone did this in a few spots where water drains alot and the metal is pristine underneath the asphalt. And definitely O'Henry's would be the cheapest alternative. My neighbor was saying to use this asphalt product they have at his work where you roller it on and the surface cures a silver color but it is black asphalt underneath. I am mainly looking for durability and am not going show or anything where anybody would be looking underneath. Of course, if they did , they would see the sick TCP sub-frame kit that I am having welded in with new frame rails this week
Old Jun 26, 2006 | 03:38 AM
67t5ponycoupe's Avatar
67t5ponycoupe
If you have a nice red oxide primer undercarrage why mess it up with any type of undercoating. You must be in a climate that is pretty dry if the undercarrage is that nice. Touch it up and leave it alone would be my 2 cents worth. That is what I did with mine. Used simple green and scrub brush and got it clean. Then just touched up a few spots with some red oxide primer. Every thing you see in the pics is original red. I had not touched it up yet
[IMG]local://upfiles/27838/C87D085978D84E6CB056F2272565FC76.jpg[/IMG]
[IMG]local://upfiles/27838/4B53E997CDFB4C4B9395AC1CBA32F48B.jpg[/IMG]
[IMG]local://upfiles/27838/1C7FA871F06547D0A65279903D35AAB7.jpg[/IMG]
[IMG]local://upfiles/27838/BEBF6A6AEAA247D0AD54428DF0E8CB38.jpg[/IMG]
Old Jun 26, 2006 | 03:59 AM
bradleyb's Avatar
bradleyb
pretty clean indeed!
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
