my car is a pool
Old Jun 26, 2006 | 12:33 PM
slick66stang's Avatar
slick66stang
Default my car is a pool
for the past two days we have gotten alot of heavy rain. new carpet new interior and there is a river coming down. i have my cowl fixed with no rust or holes.windshield gasket has no tears in it. im thinking its coming thru the rubber gasket on the fender. i was planning on covering all the holes in my firewall with gasket material and tin. has anyone ran into this problem
Old Jun 26, 2006 | 12:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: my car is a pool
If your cowl and windshield are not leaking, then it may be from the inner fender area. Take off your kick panels and see if there is a round hole there that allows water to come in behind the kick panel. Plug it if there is.
Old Jun 26, 2006 | 01:00 PM
cormy's Avatar
cormy
I have the same problem with my 66 fastback. I get water inside the passenger kick panel when I wash it. No leaks from the windsheild or cowl. Water seems to come in when I pour water into gap area between door and fender. Don't know what to do about it so I am careful when washing in that area.
Old Jun 26, 2006 | 02:33 PM
6mustang6's Avatar
6mustang6
remove kick panel, plug big *** hole. I have the same problem. It's an access to remove the embelm on the outside i think.
Old Jun 26, 2006 | 03:23 PM
cormy's Avatar
cormy
That may stop the water from coming into the interior, but it's still going to pool inside the kick panel. I perfer to keep the hole open in order to dry out the area behind if needed.
Old Jun 26, 2006 | 04:15 PM
PhillyDog88's Avatar
PhillyDog88
Keep in mind, these old cars were far from water tight anyhow. Although mine is pretty tight, I will get water coming in through the fresh air vents under the dash if it really rains hard.
I'll also get moisture in my truck at times if its really wet out so the next warm day I pop the trunk and lift the matt till all is dry.
Do your best, but expect a bit of water sometimes.
Old Jun 26, 2006 | 06:24 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: PhillyDog88
I get no water in my trunk even with a heavy down pour. I replaced the rubber seal awhile back though. Maybe you should consider doing that.
Old Jun 26, 2006 | 06:33 PM
slick66stang
i dont get water in my trunk if i do its a small amout the rubber gasket i replaced not to long ago
Old Jun 26, 2006 | 06:39 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: slick66stang
I was referring to PhillyDog's statement about his getting moisture in his trunk.
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
