console restoration question
Old Jun 26, 2006 | 10:18 PM
wags1970's Avatar
wags1970
Default console restoration question
I have a console that I want to restore for my 68 Mustang. The padding has been painted and is starting to flake off. I thought I read somewhere that its better to use vinyl dye than paint. First question is what do I use to get the old paint off the vinyl padding without damaging it and the second question is what kind of dye is best to use?
Old Jun 26, 2006 | 10:44 PM
Clu7ch's Avatar
Clu7ch
Default RE: console restoration question
i dunno about getting the old paint off of your vinyl. you may have to skin it and start again.
Old Jun 26, 2006 | 10:54 PM
1965MustangFastback's Avatar
1965MustangFastback
Ok, I’m not 100 % sure but I think if you use a soft brush and lacquer thinner it should work!
Old Jun 26, 2006 | 10:59 PM
Clu7ch's Avatar
Clu7ch
try it but be really gentle. and don't slop the thinner on it.
Old Jun 26, 2006 | 11:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
You need to take off the old paint, then order a can of vinyl paint. Use a self etching Primer then add the new color.
Old Jun 26, 2006 | 11:17 PM
wags1970's Avatar
wags1970
so if I attempted to use the vinyl dye over the paint, it wouldn't work? sounds like taking the paint off will be a trick.
has anyone successfully removed paint from a vinyl surface before? I'm afraid to damage the original surface.
Old Jun 26, 2006 | 11:38 PM
1965MustangFastback
Yes, you'll need to remove the old paint first! I don't think the lacquer thinner is going to kill it. You can always reduce the thinner, this way it's not 100 percent thinner!
Try 50/50 mix if it works your golden, if not try 80/20 mix
Old Jun 27, 2006 | 12:02 AM
ideal_mustangs's Avatar
ideal_mustangs
After you get the paint off, the vinyl dye in a can you get from the auto parts store is great. I have used in on my console and various other things, and have had it on my red truck seat dyed black for 5 years now sitting on it everyday and it hasn't worn off yet. The key is just getting it super clean.
Old Jun 29, 2006 | 09:30 PM
wags1970's Avatar
wags1970
one last question. If a console has been dyed, can it be re-dyed later another color?
thanks for all the help guys!
Old Jun 29, 2006 | 11:27 PM
ideal_mustangs
I don't see why it couldn't. Just be sure to clean it good again.
