drip rail delete
Old Jun 27, 2006 | 05:24 PM
351foxstang's Avatar
351foxstang
Default drip rail delete
i started the drip rail delete today. so far its been a real pain in the ***. i kinda wish i didn't start it, but it should look good in the end.
hopefully, ill have some pictures tonight. i can't find my camera at the moment.
carl.
Old Jun 27, 2006 | 05:46 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: drip rail delete
What are you using to grind it off with?
Old Jun 27, 2006 | 06:38 PM
351foxstang
ive been cutting it off with a 4-1/2" grinder and then welding the roof skin to the bottom piece of metal. thats the easy part. the grinding of it down after with the D/A with 40 grit paper is not fun.
im still thinking of a way to get it to be straight without building the edge up with body filler.
Old Jun 27, 2006 | 06:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
Go to the FAQ section and get that article about replacing the rear quarter panels. They use lead and some sort of other stuff to smooth it out. You shouldn't have to use much body filler.
Old Jun 27, 2006 | 07:01 PM
351foxstang
thanks soaring,
i should hopefully be getting to the filler within an hour or two. it does look pretty cool without the drip rail.
Old Jun 27, 2006 | 09:42 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
go get some metal fill bodyfiller from evercoat it works good its alumnium in a can basically alot tougher than regular filler
Old Jun 27, 2006 | 10:24 PM
351foxstang
will i be able to build up the edge with that? or will it flake off/allow water under it?
Old Jun 30, 2006 | 01:02 PM
351foxstang
a couple pictures of whats done so far. ive let it sit for a few days, it gets really boring after a while of working on it.
[IMG]local://upfiles/19521/2A4D028EF9174773B0E345AEACFC07DA.jpg[/IMG]
[IMG]local://upfiles/19521/0466BA4E923D4E138189D051C75CE617.jpg[/IMG]
Old Jun 30, 2006 | 01:59 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
its the closest thing to metal u can add short of leading the surface which would be the perferred method if u apply it properly then it will nit allow water and u can build up the surface slightly
Old Jun 30, 2006 | 02:31 PM
351foxstang
ORIGINAL: rmodel65
thanks,
ill go check to see if i can get some of that from my local store today before work. i guess it doesnt look too bad, its just almost impossible to get the edge completely straight using a d/a.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
Camster
Sep 10, 2015 11:18 AM
