Proper dash paint?
Old Jun 28, 2006 | 04:57 PM
Pughboy's Avatar
Pughboy
Default Proper dash paint?
I have received conflicting advice regarding the proper black paint for the metal part of the dash. The local mustang shop said Krylon "semi-flat" black is the proper paint, while a mail order shop says to use their "semi-gloss" black. Does anyone know the proper black paint to use?
Lee
Old Jun 28, 2006 | 05:39 PM
enzedchris's Avatar
enzedchris
Default RE: Proper dash paint?
it seems as if semi flat and semi gloss are the same thing, because half gloss means half flat don't it?, but i don't know anything about paint
Old Jun 28, 2006 | 05:56 PM
428coupe's Avatar
428coupe
ORIGINAL: enzedchris
It depends on whether you are optimistic or pesimistic. I would go with the semi gloss, or even a gloss. Save the semiflat for your engine compartment.
Old Jun 28, 2006 | 06:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
I am no expert in paint either. And I don't want to say your Mustang restoration guys are wrong, but mine appears to be semi-gloss. Take a look at the pic of mine and see what you think. It has never been painted since it came from the factory.
[IMG]local://upfiles/10034/730231AEECC04C09B530705B37ECB3A5.jpg[/IMG]
Old Jun 28, 2006 | 06:22 PM
Pughboy's Avatar
Pughboy
I agree, Soaring. The black paint on my dash, which appears original, looks like semi-gloss. I may just buy one can of each type of paint and test two small areas.
Old Jun 28, 2006 | 06:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
Now you're thinking. However, I'll bet you a cyber beer it is semi-gloss.
Old Jun 28, 2006 | 06:59 PM
Pughboy's Avatar
Pughboy
I just called the mail order shop again and mentioned the local shop's recommendation of Krylon semi-flat black. The person at the mail order shop said they have been doing business with the local shop for 20 years so if it recommends Krylon semi-flat, then semi-flat is probably right. I am going to get the semi-flat, since I can get it locally, for a test. If it is not right, I will buy the semi-gloss from the mail order shop for another test.
Old Jun 28, 2006 | 07:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
OK. Good thinking. I still bet the cyber beer.
Old Jun 28, 2006 | 07:37 PM
Pughboy's Avatar
Pughboy
ORIGINAL: Soaring
You're on. I should have an answer on the semi-flat by this weekend.
Old Jun 29, 2006 | 12:49 AM
ideal_mustangs's Avatar
ideal_mustangs
Originally it was a charcoal metallic black.
lincolnshibuya
Oct 6, 2015 08:45 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
breaking
Oct 2, 2015 01:27 PM
GLOCKer
Sep 28, 2015 07:36 AM
Sep 25, 2015 06:42 PM
