update on body work for my mustang
Old Jun 28, 2006 | 08:39 PM
atomsk680's Avatar
atomsk680
Default update on body work for my mustang
ok, i stripped the paint from the areas i know i have rust and sanded all i could by hand. then i brought out the air grinder and after i finished with about a 1/4 of all the areas i need to grind down, my compressor stopped working. so i called it a day, took some pics, and came inside. here is what it looks like after 2 days of paint stripping, cutting myself on rust, going to the hospital for a tetanis shot, coming back and continue working.
thats my dads mach 1 in the garage
Old Jun 28, 2006 | 09:24 PM
baddog671's Avatar
baddog671
Default RE: update on body work for my mustang
Ouch, that door...
Old Jun 28, 2006 | 09:28 PM
robthedolphin's Avatar
robthedolphin
An anarchy sign on a Ford?(or at least it looks like one above the drivers side rear wheel)
Old Jun 28, 2006 | 10:08 PM
fast66's Avatar
fast66
Are you going to repair the rust holes with steel? or just going to bondo it up? I looks as though there is still a lot of paint and bondo around the rust areas which will still need to be removed, especially if you are going to weld new metal in. I used some discs from 3M called "clean and strip" They cut through paint and bondo really easily, but dont cut or damage the metal surface at all. I've found them a lot better to use that grinding discs, or sanding discs. Of course Im in Australia, and I don't know if you can get them in the US, but there will definitely be something similar.
Old Jun 28, 2006 | 10:09 PM
EmperorOfChicken's Avatar
EmperorOfChicken
I like how some one spray painted or somethin 69 on the door, like we didnt know it was a 69, or you couldnt put a sign on it, so they spray painted it lololol [8D]
Old Jun 29, 2006 | 01:10 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
why did u have to get a tentanus shot? rust is inorganic! was it a deep puncture wound u would need a booster if it was. its an old wives tail about rusty objectsusually nails cause they are usually the deep punctures wounds
Old Jun 29, 2006 | 02:48 AM
atomsk680's Avatar
atomsk680
first off, its not painted on 69, my chemical stripper is in a spraycan, and i had to wait 10-15 minutes, and i got bored so i stripped off a portion in the shape of a '69'. second, my brother put the anarchy thing on there, and i got most of it off. third, i was getting the aint and bondo off, and it turns out my powerstrip blew, thats why my air compressor stopped working, but now that it is fixed i have all day tomarrow. fourth, im not bondoing anything if i dont have too those clean and strip things, but ill go look around tomarrow morning. and finally, it was kind of deep, about a quarter of an inch, my mom took me cause she was freaking out, i didnt mind, i got out of work
Old Jun 29, 2006 | 04:03 AM
baddog671's Avatar
baddog671
Walmart carries a liquid paint stripper u brush on that will be much cheaper and faster. U could do a hood in a half hour. I think its 5 bucks for a quart. I did my entire trunk area with it and have half the can left...
Old Jun 29, 2006 | 04:07 AM
atomsk680's Avatar
atomsk680
ORIGINAL: baddog671
guess im going to walmart tomarrow. i only got the kind in a can so i could strip the rust area's first.
Old Jun 29, 2006 | 04:13 AM
baddog671's Avatar
baddog671
If your talking about the aircraft paint stripper in a can, thats expensive. Im not sure of the coverageof the cans, but im positive the liquid will do more surface area. Just buy 2 cans, and acouple cheap paintbrushes. It will bubble up and practically fall off. I used a putty knife to scrape it off faster.
