Interior wrinkle paint?
Old Jun 30, 2006 | 09:26 PM
ridebadger's Avatar
ridebadger
Default Interior wrinkle paint?
Will someone please explain the process to reporduce the "wrinkle" paint pattern on the interior of the doors on a 66 stang? Is it hard to reporduce? Is there a different term used to describe the pattern? Thanks
ridebadger
Old Jun 30, 2006 | 09:33 PM
coda618's Avatar
coda618
Default RE: Interior wrinkle paint?
I don't know another term. However, I believe the metal itself is textured. You have to be careful not to sand down the texture if removing the old paint. Also, if they have been sprayed before on top of original paint, the paint buildup can flatten out the texture as well. So the paint will have to be removed to get the texture back. I would think a non-abrassive method such as a liquid stripper would be the best method.
Good luck.
Old Jun 30, 2006 | 09:38 PM
67t5ponycoupe's Avatar
67t5ponycoupe
The wrinkle is the metal not the paint
Old Jun 30, 2006 | 09:42 PM
ridebadger's Avatar
ridebadger
Thanks a lot. I had a suspicion that it wasn’t the paint but wanted to check. Can you recommend a stripper? (the paint kind )
Old Jun 30, 2006 | 10:23 PM
ideal_mustangs's Avatar
ideal_mustangs
I used some on a motorcyle once. It was in an aerosol can and very easy to use. Krylon OFF
Old Jun 30, 2006 | 10:31 PM
EmperorOfChicken's Avatar
EmperorOfChicken
is it different than KRINKLE (sp?) like what is used on some valve covers?
Old Jul 1, 2006 | 12:33 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
u can get the grain back spray the color u want let it get dry enought to touch but not stick(will finger print lay a towel on the paint and press doen will give u texture
Old Jul 1, 2006 | 12:53 AM
ACADIST's Avatar
ACADIST
If you know how to paint you can acheive texture by turning down the air pressure in your gun on the second coat. It is a technique that requires some experimentation and practice.
Old Jul 5, 2006 | 01:14 PM
ridebadger's Avatar
ridebadger
Thanks for the info everyone!
ridebadger
Old Jul 5, 2006 | 01:40 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: ideal_mustangs
the aircraft stripper would probably also work, whicher one's cheaper would be fine.
