right rear tire locking
Old Jul 2, 2006 | 04:31 PM
juniorb_41's Avatar
juniorb_41
Default right rear tire locking
recently my 66 with right rear tire (drum brakes) began locking up very easily when breaking. the weird thing is that when i hit the breaks it locks up even when i release the break pedal ( i realize that drum breaks purposefully jam, so maybe that could be the cause) however than you can feel the break still on as i drive for about another ten yards. at first i was thing maybe a proportioning valve issue, but the staying locked makes me believe its something mechanical like bad springs. but i really dont know and any help would be greatly appreciated.
Old Jul 2, 2006 | 04:41 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: right rear tire locking
Need to open it up and see what is going on in there
Old Jul 2, 2006 | 04:45 PM
randy78045's Avatar
randy78045
get some brake cleaner an clean everything up... dont spray it on the linings though... inspect the linings for grease an contamination...
Old Jul 2, 2006 | 04:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
It could be several things. That's why you need to take the hub off, clean everything up then inspect it. It could be the wheel cylinder hanging or the shoes grabbing due to excessive brake dust or brake fluid if the wheel cylinder is leaking, etc. You could also be running metal to metal if the shoe is worn down sufficiently, which would tend to make it grab.
Old Jul 2, 2006 | 06:59 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: Soaring
exactly. i'm not sure what mine was on my 89 but it was either the cylinder or something with the e-brake not fully releasing. by the sounds of what you are saying, it's probable the cylinder, but do check the other things mentioned by other members, they are also very feasable.
Old Jul 3, 2006 | 02:27 PM
juniorb_41's Avatar
juniorb_41
Thanks guys im going to open it up today.
Old Jul 4, 2006 | 01:16 PM
MidNite27's Avatar
MidNite27
Is the master brake cylinder a common thing to die on our classic mustangs? Because last night on my way home i pretty much lost power brakes lol. It wasnt fun. In addition my right rear drum brake has been locking up tempermentally when medium-high braking
Old Jul 5, 2006 | 01:13 AM
MidNite27's Avatar
MidNite27
*mini bump*
Old Jul 5, 2006 | 03:53 AM
Clu7ch's Avatar
Clu7ch
ORIGINAL: MidNite27
*mini bump*
*mini me*
i'm sure, like all things in this world, they are bound to start to fade with time. your losing the power may be a small amount of air in the system and your locking up may be a bad cylinder. you sould crack it open and take a look at the cylinder.
Old Jul 5, 2006 | 01:35 PM
4Stangs's Avatar
4Stangs
When you open it up, I think you may find rear-end grease from a leaking axle seal. If not, re-build or replace your wheel cylinder and make sure everything is dry and clean.
