synthetic oil question
Old Jul 2, 2006 | 10:51 PM
jroseman's Avatar
jroseman
Default synthetic oil question
i just rebuilt my heads and installed new rings and rod bearings in my 306 about 100 miles ago. i have always run valvoline straight 30 weight. thinking of going to a synthetic. anything special i have to do in the change? is it worth the extra money? what weight and brands are good?
i put about 6000 miles a year on my car. not a daily driver but a frequent driver. i take it on 500 - 1000 mile trips from time to time.
Old Jul 2, 2006 | 10:57 PM
paladin_1888's Avatar
paladin_1888
Default RE: synthetic oil question
A lot of the oils that say synthetic are really petro based, look for a true synthetic like mobil one, redline or amsoil.
Old Jul 2, 2006 | 11:00 PM
pony girl 05's Avatar
pony girl 05
I dont use anything but mobil 1 in my car I think it is worth the money
Old Jul 2, 2006 | 11:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
There have been a few tests as to which synthetic oil is best, and Royal Purple, Amsoil, Redline and Mobil 1 usually head the list of the best ones to use. Go ahead and use the dino break-in oil to get your rings set, then switch to the synthetic. The advantage of using something like Royal Purple and Mobil 1 is that you can get it locally, and not have to go through a dealer. Mobil 1 is even available at Wal-Mart. Using a straight 30 weight oil is not a good idea as it doesn't have the sudsing action to keep your engine clean. A 10-30 synthetic will suit your needs just fine. There have also been studies done on filters. Wix and Motorcraft are good filters for our cars. Just don't ever consider Fram filters. We have these studies in the FAQ section if you care to read them. More info here. http://www.synlube.com/oil.htm
Old Jul 2, 2006 | 11:35 PM
jroseman's Avatar
jroseman
with the mobil 1 or the redline - how often do you recommend changing the oil and/or filter?
i always use the motorcraft filter. it just feels right. gladt to know it is also the best.
Old Jul 2, 2006 | 11:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
Most synthetic oils are designed to run 10K miles or even more, with an oil filter change at 5K miles. These are conservative figures, as they don't want to get sued.
Old Jul 2, 2006 | 11:44 PM
pony girl 05
ORIGINAL: Soaring
do you really wait that long in between oil changes? maybe Im changing mine more than I need to I always change it every 3000 miles
Old Jul 3, 2006 | 12:08 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: pony girl 05
ORIGINAL: Soaring
Yeah, with dino oil, the 3-5K miles between changes has been traditional for eons, but with synthetic, you can double the mileage with a filter change at around 5K. If you are changing every 3K with synthetic, you are wasting money. The synthetic does not break down as soon as dino, and with the filter change you are eliminating much of the pollutants.
Old Jul 3, 2006 | 01:30 AM
juspay4speed's Avatar
juspay4speed
go with Mobil one or Royal Purple, i use the Mobil one filters and run 3,000 miles or so for every oil change, with the way i drive thats like once a month, it maybe a little obsessive but my Toyota Previa has 318,xxx and is still going strong, my 99 V6 has 164,193 and is still doing great!
Old Jul 3, 2006 | 01:33 AM
pony girl 05
ORIGINAL: Soaring
ORIGINAL: Soaring
cool than Im not due for an oil change after all
