65 automatic
Old Jul 7, 2006 | 04:52 PM
StPat's Avatar
StPat
Default 65 automatic
I have an 1965 Mustang fastback that I am in the process of putting back together. It has 289/auto, I've gone through the engine and now it's time for the transmission. Are the early C4's difficult to rebuild/ Is it the sort of job best left to a shop. This car was bought new by my brother in law so I am the second owner, has been through lots of kids and everything is pretty much worn out but if I can get it back running and driveable it will make things a lot easier.
Thanks
Patrick
Old Jul 7, 2006 | 08:34 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: 65 automatic
Take it to a good shop. You don't want to try that yourself.
Old Jul 7, 2006 | 09:15 PM
magic_man77's Avatar
magic_man77
I would also recommend taking it to a shop. I just had me C4 rebuilt for about $525 but that was with a 3000 stall converter. It runs SWEET!! Instead of using the stock '65 trans that I could manually shift into "L", "2", or "D", I took one out of my '66 that I could manually shift to "1", "2", or "D". Much better for just your average street racing. Your rebuild should only cost you around $350 - $400 tops. My converter was almost $200.
Old Jul 7, 2006 | 09:17 PM
magic_man77
Sorry. I meant that the '65 original trans I could only shift into "L" and "D".
Old Jul 7, 2006 | 09:21 PM
StPat's Avatar
StPat
Thought that would be the answer, I really did not want to tie into this myself. So off to the shop it goes.
Thanks
Patrick
Old Jul 7, 2006 | 09:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, your C4 should have three definite gears. If your second gear is not not working, it's time for a rebuild. But, first check you linkage to make sure everything is hooked up.
b8checker
Oct 8, 2015 12:55 PM
guitarman376
Sep 30, 2015 05:54 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
