New carpet
Old Jul 8, 2006 | 06:05 PM
palerider's Avatar
palerider
Default New carpet
Having floor pans replaced in my 1970 fastback. Local body shop is doing. I stripped out old carpet before taking over. Planning on replacing carpet and insulation. right now just planning to order from NPD or CJ Pony had good luck with both. Just curious if anyone has any tips or maybe better source for carpet. Thanks
Old Jul 8, 2006 | 06:12 PM
Cogtx's Avatar
Cogtx
Default RE: New carpet
Bought my carpet from Virginia Classic Mustang. Great fit with very minimal need to trim. Also put down some "peal and stick" sound insulation to reduce noise....good luck!!!
Old Jul 8, 2006 | 06:18 PM
MidNite27's Avatar
MidNite27
Get the right Torx bit to remove the seat belts. Scalpal works pretty good for trimming but get sometin nice and sharp.
Old Jul 8, 2006 | 09:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
I used a box cutter with a new blade. Be very careful not to trim too much off under the dash until you get it all laid in and pressed into all the corners, etc. Make damn sure your floor pans have been prepped with seam sealer and primer and paint before you put the carpets down.
On edit: I forgot to mention to get new underlayment with the new carpet. The old one will most likely be trash, and you definitely need it for road noise muffling.
Old Jul 8, 2006 | 10:48 PM
ngirg001's Avatar
ngirg001
anyone know the best adhesive to keep the carpet from moving?
Old Jul 8, 2006 | 10:53 PM
Todd1919's Avatar
Todd1919
For better sound proofing you can use some sound proofing mats, I did my whole car this stuff is suppose to be better than dynamate and a lot cheaper. You need at least 100sq feet to do your car, but if you want to do everything including the roof you need at least 150 sq feet or 3 rolls. Here's a link for the cheapest I could find and getting it off of ebay is way cheaper than from there website.
http://cgi.ebay.com/ws/eBayISAPI.dll...SI_PR4_PCN_BIX
Old Jul 8, 2006 | 11:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: ngirg001
If you installed it correctly, the carpet won't move with the new underlayment. Howerer, 3M makes a spray adhehive that works well.
http://www.mpsupplies.com/3msprayadhesive.html
Old Jul 9, 2006 | 04:08 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I used 3M's rubberized undercoating under the carpet in my '71. I can't say if it reduced noise, but it will definitely protect from moisture (wet shoes, busted heater core[:@], etc.) I ordered mine from Mac's Auto Parts and had no problems with fitment. It did come with insulation attached and had the proper rubber pad under the pedals.
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
kirk35
Aug 17, 2015 08:42 PM
Bryan@Autogeek
Aug 5, 2015 12:33 PM
