302 problems no low end
Old Jul 10, 2006 | 03:39 AM
66_Stang306's Avatar
66_Stang306
Default 302 problems no low end
Hi all new here. seems like alot of knowledgeable people here, sorry for such a long first post.
Heres the run down.I built this engine for my 66 mustang (289 was done)Heres what i have in the engine H.O Flat tops .30 all arp bolts etc stock rods, edelbrock RPM heads w/ trick flow 1.6 rockers, RPM air gap intake, Ford racing E303 cam, 670 cfm holley, all MSD ignition. I had the car on the DYNO long enough to find out jetting was dead on but i had a small oil leak and had to stop the run.
The problem is no torque it lugs off the line and never really pulls i can be at a 30mph roll in 2nd go back to 1st gear it will rev to 6000 no problem but it just sounds good i'm really not going anywhere. For what i have in this engine it should pull way better then it does. I went over timing,cam timing, air leaks checked plugs everything is how it should be but it just dont run right i'm lost.
The trans is a TCI built C4 with a 1900-2100 stall. 9ich rear with 3.70 gears.
I looking more at the cam being the problem not enough stall for the power band, the car is more of a street machine then a racer although i want to hold my own in a little red light to red light action.
I never had a SBF with all new parts run like this one i bet the problem is something i'm over looking.
Any help would greatly be appreciated.
Dennis
Old Jul 10, 2006 | 04:04 AM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: 302 problems no low end
initial timing and how much fully advanced? You put the cam in straight up?
Old Jul 10, 2006 | 10:28 AM
moparmatt89's Avatar
moparmatt89
Hey,
Sounds like an awsome package, but your stall sounds too low for the combo you are have. I have a similar combo but with a slightly smaller cam and it calls for at least a 2500 stall. I dont beleive that is totally to blame for your problem, but it is definatly robbing you of some off the line, low end power.
Matt
Old Jul 14, 2006 | 02:03 PM
66_Stang306
The cam is set +4 (get more compression at low rpms). I really dont want a big stall, my wife does drive the car once and a while and she wouldnt like it or she would end up in someones living room. I'm trying to find a way i can get more low end grunt without hurting the drivability too much.
Thanks Dennis
Old Jul 14, 2006 | 02:46 PM
myshifter's Avatar
myshifter
I ♥ Acer
what is the intial timing and total timing?
Old Jul 15, 2006 | 01:42 AM
66_Stang306
The guy thats doing the down work (when i can keep him on the job) has it running at 15 and 28-30 total.
Thanks,
Dennis
Old Jul 15, 2006 | 01:46 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I run 10 degrees at 1000rpm, and 38 total by 2500rpm with a bit larger cam.
Old Jul 15, 2006 | 01:50 AM
THUMPIN455's Avatar
THUMPIN455
If you can, post some pics of your engine. Not from 30 feet away, but a nice overall underhood shot. Sometimes things jump out at you when looking at a pic like that. its really difficult to diagnose a problem online, more info always helps.
Even with the stall you have it should leave a couple black marks when you floor it. Have you checked the brakes? Is the park brake on? I know silly question but you would be surprised at how many times something like that is the cause.
You do realize your best et would be around a low 14 to a mid 13 right? If you have been driving anything else that runs better than that it will seem slow in comparison. Just a thought, since some of us have vehicles that range from pathetic to incredibly fast, and when I drive the F150 after a few passes in the 10 second car, it feels woefully inadequate...
Old Jul 15, 2006 | 01:51 AM
66_Stang306
Thanks for the input.
I just remembered something when i last drove the car it seemed to run better and pull off the line harder with less timing more on the retarted side it really has me thinking WTF everytime i mess with it. I really havent had alot of time to go over the car with all the hours i have been pulling the past few weeks.
Dennis
Old Jul 15, 2006 | 01:54 AM
66_Stang306
I know its hard to get an idea over the net just hoping to get some ideas of what to check out. As for power, with all this it will have a hard time breaking the tires lose from a dead stop, it just dont seem right to me like something isnt there. I'll get a photos up here in a few minutes. As for brakes it has all wheel disc with no parking brake, all wheels move freely.
Dennis
