replace I6 with v8
Old Jul 10, 2006 | 11:55 AM
jeremy71's Avatar
jeremy71
Default replace I6 with v8
I have a 66 coupe that i am looking at replacing the 6 cylinder with a 289 I know i will have to replace the coil springs and radiator. Will I also have to replace the rear end?
Old Jul 10, 2006 | 12:17 PM
atomsk680's Avatar
atomsk680
Default RE: replace v6 with v8
yes, and the suspension and the transmission and pretty much the entire drivetrain. che ck the FAQs, there is a few links in there that will show you exactly what you need to convert your car correctly.
Old Jul 10, 2006 | 12:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: replace I6 with v8
I edited your heading to say I6 instead of V6. There were no V6 Mustangs back then. This has been done a lot, and can be done with a lot of time and effort and money. Basically, the front suspension has to be upgraded to a V8 suspension with 5 bolt hubs, and if you have a 3 speed manual, that tranny will have to be replaced because it is a weak 3 speed that came with the sixers. The rear end has to be upgraded to at least an 8" rear with 5 bolt hubs. The 7 1/2 inch rear in the six is just too weak for a V8. The engine wiring harness will have to be replaced. This is just the tip of the iceberg. Usually, it is cheaper to start with a V8 car and upgrade from there than it is to replace all the sixer stuff to make it a V8 car.
Old Jul 10, 2006 | 12:57 PM
jeremy71's Avatar
jeremy71
Thanks
Old Jul 10, 2006 | 07:33 PM
Clu7ch's Avatar
Clu7ch
and if you have a 3 speed from your I6 (200ci, i'm guessing?), i know someone who will gladly take it off your hands *wink, wink* *nudge, nudge*
Old Jul 10, 2006 | 08:57 PM
atomsk680's Avatar
atomsk680
ORIGINAL: Clu7ch
thanks for thinking about me first clu7ch, but im looking for a 5 speed
Old Jul 10, 2006 | 09:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: atomsk680
ORIGINAL: Clu7ch
Clu7ch was talking to Jeremy. Go back to sleep.
Old Jul 10, 2006 | 09:25 PM
atomsk680's Avatar
atomsk680
ORIGINAL: Soaring
ORIGINAL: atomsk680
ORIGINAL: Clu7ch
dont have to tell me twice. how did you know i was napping??
Old Jul 11, 2006 | 04:57 AM
Clu7ch's Avatar
Clu7ch
ORIGINAL: atomsk680
ORIGINAL: Soaring
ORIGINAL: atomsk680
ORIGINAL: Clu7ch
cause you totally missed the humor in my post. wait, there was no humor. i really am looking for a three speed for my I6. [&o]
Old Jul 11, 2006 | 06:44 AM
Colorado_Mustang's Avatar
Colorado_Mustang
ORIGINAL: Clu7ch
Too bad I didn't know that earlier. There's one in the Weld County land fill if you want... And it was from behind a V8.
Personally, go for the 4-speed WR. You'll really appreciate that extra gear ratio right before straight through...
