engine swap
Old Jul 13, 2006 | 10:30 PM
ormsby's Avatar
ormsby
Default engine swap
i baught a 65 mustang(289) from a guy and the engine was sizied so i got a engine out of a 86 mustang(302) and i was going to put back together with te balencer off of the 289 so i wouldnt have to buy a new pulley. ive been told that it that it has to be 56oz or somthing like that but i looked in summit and they have all diff. weights. i was woundering if yall could advise me on this? Also im planing on using the old fly wheel but i dont know if it has to be a certain weight and will the distributar out of the 289 work in the 302?
Old Jul 14, 2006 | 12:05 AM
middiepride's Avatar
middiepride
Default RE: engine swap
whats up. you need a 50 oz balancer or flywheel. if auto a balancer if manual a flywheel.I dont know about distibutor. hopefully this helps.
289 is a 28 oz
302 is a 50 oz
fordmuscle.com has this on it
Old Jul 14, 2006 | 12:15 AM
Silver Ponys's Avatar
Silver Ponys
The dizzy will work lenght wise if the 302 has a roller camyou will need a hardened gear on the dizzy
Old Jul 14, 2006 | 12:36 AM
ormsby's Avatar
ormsby
i have an automatic so i need the ballancer do yall no if the pulley for the 86 has the same belt grooves because the old one wont bolt up to the ballancer
Old Jul 14, 2006 | 12:43 AM
Silver Ponys
The 86 wont have the same pully but after market suppliers can fix you up. You will need the right flex plate also
Old Jul 14, 2006 | 01:05 AM
mustanglover66's Avatar
mustanglover66
you need a 50oz balancer and a 50oz flexplate. you can get a balancer from summit or others that have the 3 and 4 bolt hole setups on them so you can use your 65 pulley.
Old Jul 14, 2006 | 03:26 AM
Colorado_Mustang's Avatar
Colorado_Mustang
ORIGINAL: middiepride
289 is a 28 oz
302 is a 50 oz
Just a little clarification. Only 302's after about mid-1980 are 50oz. Earlier models are 28oz.
Old Jul 15, 2006 | 05:33 PM
deadcarnahans's Avatar
deadcarnahans
ORIGINAL: ormsby
This is a very practical swap if you pay attention to the other posts as well as mine.
You must use the 86 front balancer. You will not be able to use the 289 pulleys, water pump, and alternator mounting brackets.
(I can send you detailed photos of this swap and installation if you wish)
I used early 70s style 302 pulleys, waterpump, and alt brackets. Single groove pulleys driving the pump and alt. No other accessories.
The bummer about this is the water pump outlet is on the driverside so you will have to take your radiator to the shop and have the lower neck relocated to the opposite side. They can do this for about $50, but you should splurge and get a new unit anyway.
You will also need an early 302 timing cover, dipstick, fuel pump eccentric. The 289 pieces might work also with some minor mods.
Use the 289 oil pan and oil pump pick up tube.
Plug up the dipstick hole in the 86 block.
As the others say: Never ever ever put an early distributor in a later roller cam block. I've seen it done and I've seen the results.
I wont get into that issue now.
The back of the motor depends on what tranny you have. My experience is with AOD and T-5 swaps.
Assuming that you do have a manual transmission, the 86 block was not cast with the mounting boss for the equalizer bar pivot. You have to make one or buy one (is available).
You may very well have to buy a new flywheel that is balanced for the 86 but is drilled to mount an early clutch.
I think this is the bulk of it.
Go for it...
Old Jul 15, 2006 | 05:39 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: deadcarnahans
ORIGINAL: ormsby
Go for it...
yeah! what he said.
beat me to it you poo head!
Old Jul 15, 2006 | 07:58 PM
hutchamatic's Avatar
hutchamatic
Proformance make a balancer for the 50oz with both bolt patterns so you can use your orginal pulleys. MSD and Crane make a steel dist gear which has to be used. Your flywheel is 157 teeth. These are also available in the 50oz size. I have done many of the change overs. Reuse your original timing cover, install your fuel pump eccentric.
