Rust problems please help
Old Jul 14, 2006 | 04:45 PM
Andrew7's Avatar
Andrew7
Default Rust problems please help
Hi, I have a 69 fastback and I have a ton of rust under the cluch pedal in the interior and it looks to be rotted through directly below the clutch pedal. Does anyone know what that part is called and how big of deal it is to replace, it looks like I cant access it from below. Thanks for any advice.
Old Jul 14, 2006 | 04:49 PM
P Zero's Avatar
P Zero
Default RE: Rust problems please help
Its called the floor pan. And replacing it is pretty involved. Call around to body shops and ask them what they would charge to put one in.
-P.
Old Jul 14, 2006 | 04:51 PM
muggsy's Avatar
muggsy
I know in a 67 its called a firewall extension pan. It usually means there are more floor issues than just that one...not to freak you out, not a huge deal.
Old Jul 14, 2006 | 04:56 PM
muggsy's Avatar
muggsy
Oh, and I had mine replaced this past spring. rarely just one is bad. Mine led to all floor pans and some rocker issues as well. Have it looked at, but its not uncommon in old Mustangs. Often times the firewall extension pans are gone beacuse of the cowl leaking vs. the obvious undercarriage rust. Not sure if 69s had the infamous cowl issue like the 65-68s do...
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
GPR
Dec 16, 2015 12:21 PM
FivePointToTheOh
Oct 2, 2015 04:09 PM
Sep 17, 2015 07:57 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
