Autolite or Edelbrock?
Old Jul 14, 2006 | 05:23 PM
David Wallace's Avatar
David Wallace
Default Autolite or Edelbrock?
I have a 1967 Mustang with a 289 that was equipped with 2 barrell set up. I have switched over to original cast iron 4 barrell intake but would like the suggestions of others whether it is better to go with a Pony-built Autolite 4 barrell or go with something like an Edelbrock 4 barrell?
I'd like to stick with stock carb but if there are advantages in going with an Edelbrock, then I may consider that route. Thanks.
Old Jul 14, 2006 | 05:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Autolite or Edelbrock?
The Autolite/motorcraft 4100 is the original carb for the "A" code mustangs. It is bullet proof and easy to dial in. They are expensive from Pony Carbs though, and they are only 450 or so CFM's, but if you are sticking with stock, then you will be pleased with it.
Old Jul 14, 2006 | 05:30 PM
myshifter's Avatar
myshifter
I ♥ Acer
T Minus 5 minutes The edel/carter carbs are great daily drivers, heres a few happy pony buyers. http://www.fordmuscle.com/forums/all...rbs_52388.html
Old Jul 14, 2006 | 06:07 PM
jrrhd73must's Avatar
jrrhd73must
I love my Edelbrock set up.
Old Jul 14, 2006 | 07:35 PM
Smothers's Avatar
Smothers
ORIGINAL: myshifter
If you read all the responses, only the first guy was happy. The rest were disappointed.
edit: NM, they were not happy with the carb service, not the actual carb
Old Jul 14, 2006 | 07:38 PM
slickman's Avatar
slickman
I second that!!
ORIGINAL: jrrhd73must
Old Jul 14, 2006 | 07:57 PM
myshifter's Avatar
myshifter
I ♥ Acer
ORIGINAL: Smothers
ORIGINAL: myshifter
I was being sarcastic actually. I think the carbs are good, I think his policy is a bit rough
Old Jul 14, 2006 | 08:14 PM
edawg17's Avatar
edawg17
Stick with the autolite!
Old Jul 14, 2006 | 08:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: myshifter
ORIGINAL: Smothers
ORIGINAL: myshifter
OK, I think we all agree the 4100 is a good carb, but perhaps Pony Carbs is not the place to get a rebuilt 4100 because of the aforementioned problems. Where else can we get a rebuilt 4100 carb? Do the parts places carry them such as AutoZone? Here is one online, but I have no idea if they are better than Pony Carbs.
http://www.gyrhead.com/carb.html
Old Jul 14, 2006 | 08:32 PM
David Wallace
I ordered one through JJ's Mustang Parts who gets them through Champion. About four months after I ordered one, I finally got around to making the switch fom 2 barrell to 4 barrell and the carb was no good - running waay to lean. So I sent it back. The 2nd one they sent me did not have any type of male filttings coming out from the fule lines or vacuum advance. So off to look for those. Checker, AutoZone, Ace, NAPA and finally Loper's here in Phoenix. Lopers sold me some fittings which ended up stripping both sections.
So at this point I'm ready to ditch my Autolite core and just go get an Edelbrock. I'd like to keep original parts in my numbers matching car but as my mechanic said, "no one sees the carb with the air cleaner on."
Thanks for your opinions thus so far.
