T5 conversion help
Old Jul 15, 2006 | 01:58 AM
mustang289's Avatar
mustang289
Default T5 conversion help
So i've got some money saved up and im thinkin about doing the T5 conversion in my 65 with a 289 currently with the hp absorber cruise-o-matic as of right now, after reading all the articles and such, i will need the 28oz flywheel and a throw out bearing for a T5 and a new starter from a late model along with a new clutch (what size im not exacly sure) and then im going to convert to clutch cable and i know im going to need a clutch pedal and T5 bell housing and spacer plate to accomodate for the 1 inch longer input shaft, and i kno im going to need a small slip yoke is there anything that you see that i am missing, i am probably not thinking of something right now, but if you all have any tips or tricks or advice i would love to hear it, thanks guys
Old Jul 15, 2006 | 02:07 AM
mustang289's Avatar
mustang289
Default RE: T5 conversion help
ooops forgot about the block plate...
Old Jul 15, 2006 | 02:21 AM
mustang289's Avatar
mustang289
and forget the part about the spacer for i will be using a T5 bell housing so i will not need it....
Old Jul 15, 2006 | 10:34 AM
Cannonball888's Avatar
Cannonball888
If your car originally had a 4-speed toploader you would have to enlarge the tranny tunnel to accomodate a T-5, but I don't know if it is necessary since your car has an automatic. You may want to research that too.
Old Jul 15, 2006 | 01:06 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: Cannonball888
either or, the tunnel must be cut and massaged. i don't know exactly how far it needs to be moved, but it needs to be cut and lifted about an inch, give or take and the opening for the selector/shifter may need to be widened too.
i believe you said you already read articles about it and such, but do try the FAQ's page again, there are at least 2 links there about the T5 and installing it. they should tell you a little more and you could also try google'ing it.
Old Jul 15, 2006 | 05:11 PM
Shifty101Easy's Avatar
Shifty101Easy
ive never heard that metioned ever in a T5 swap conversation.....enlarging the tunnel? arent they all the same and the onlyk diff between manual and auto is the little piece of sheetmetal u can pop out for the clutch pedal through the firewall etc.....???
Old Jul 15, 2006 | 05:20 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: Shifty101Easy
no. for the 64 1/2-66 the tunnel is too low to accomadate ANY trans with OD. the tunnel must be worked and a different trans mount used for it to fit right. 67 and up are good. they have th extra room needed to fit the trans in [Ace Ventura voice]like a glllove[/Ace Ventura voice].
so, yeah, i think it was one of the links in the FAQ's that showed how the tunnel had to be modded. either that or the thread i had a while back asking about them. found a lot of good stuff on the swap, now if i could find a suitcase full of 100's . . . . . [>:]
Old Jul 15, 2006 | 07:27 PM
hutchamatic's Avatar
hutchamatic
I have done three and no mods on tunnel.
Old Jul 15, 2006 | 07:54 PM
Clu7ch's Avatar
Clu7ch
what years, because i know i specifically read that the 65-66 models needed to have the hump massaged in order to get a good clean fit. early model cars weren't designed with OD transmissions in mind. they were normally 3 speeds.
Old Jul 15, 2006 | 08:10 PM
hutchamatic
66
