289?
Old Jul 21, 2006 | 08:03 PM
njkid's Avatar
njkid
Default 289?
my pops is looking at a 64 mustang. man is he getting this thing for a steal. he wants to punch the 289 0.30 over. what would it make the 289?
thanks for comments
Old Jul 21, 2006 | 08:22 PM
grruminator78's Avatar
grruminator78
Default RE: 289?
I'd say a 290 or so.
Old Jul 21, 2006 | 09:22 PM
bob emmerich's Avatar
bob emmerich
Default RE: 289?
A 289 with a standard overbore. That's about as far as you want to go on a 289 as the cylinder walls are super thin.
Old Jul 21, 2006 | 10:17 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: 289?
Do the math. Bore(include the overbore, .030 over on the bore will add .060 to the bore size) X Stroke X 8 = CID
Old Jul 21, 2006 | 10:27 PM
6mustang6's Avatar
6mustang6
Default RE: 289?
Hey ponycoupe... unless im doing something wrong, or looking at something wrong, that formula doesn't work. I keep getting 90 something..........
Old Jul 22, 2006 | 12:06 AM
Cannonball888's Avatar
Cannonball888
Default RE: 289?
My engine caluclator says 294
And it's 0.030" over, not 0.30"
Old Jul 22, 2006 | 12:10 AM
6mustang6's Avatar
6mustang6
Default RE: 289?
yeah, i put it in my engine calc and got 292......
Old Jul 22, 2006 | 12:21 AM
67t5ponycoupe
Default RE: 289?
Ok lets try this. The bore on a 289 is 4 inches. If you machine .030 of the cylinder wall then you make the the bore 4.060. You understand why this is right? Take .030 off the wall arouind the entire circumference of the hole, it makes the hole .060 bigger. So, take 4.060 x ... oops I see my mistake. first we need to find the area of the top of the piston basically. pi R squared. 4.060 is the diameter. half of the diameter is the the radius or 2.030. So 2.030 X 2.030 X 3.14 (Pi) = 12.939626. Now we have the area of the top of the piston. so, we need the volume the piston displaces from tdc to bdc or stroke. So that would be 12.939626 X 2.87 (stroke) = 37.13672662. that is the volume that one cylinder displaces. To get total displacement multiply that by 8. 37.13672662 X 8 = 297.09381296. sorry I guess I didn't think about it enough when I posted that before. There is your answer 297.09381296.
Old Jul 22, 2006 | 12:24 AM
67t5ponycoupe
Default RE: 289?
Are you saying that if you bore a cylinder out .030 that the hole doesn't get .060 bigger? I'm pretty sure it does. So your bore should be 4.060.
Old Jul 22, 2006 | 01:09 AM
6mustang6's Avatar
6mustang6
Default RE: 289?
i always thought it got .030 bigger, not twice that.
