Body Work Question
ok i so i patched up some holes and body fillered them and all that...now i want to prime over them to keep them from absorbing moisture and what not.......
can someone point me out where to order or go pick up a can of rattle can primer???? thanks
ORIGINAL: Shifty101Easy
should it be self etching primer? i dono what the difference is?
Here is an example of a decent self etching primer.
http://www.duplicolor.com/products/primer.html
get a premium primer from the autoparts store or wal-mart (3.50 as opposed to a 1.00) Spray a couple of coats. Get some scratch filler, put over small pin holes and scratches. Sand, paint with primer and repeat. NOTE: body filler goes on bare metal or other body filler; scratch filler goes on primer.
hmmm very interesting....i cant find any sort of primers or anything online at walmart.com .....maybe they only have it in stores.......i guess i could try to go there tonight....i went to this little paint store type thing today......20 bucks for a can.....i dono about that if ur saying 96 cents lol........
what does "etching" really mean??
self etching primer is a good deal but will not seal off moister! it after a while will break down because it is designed to be top coated with paint. if i was you i would decide what kind of paint products you plan on using (ie. dupont, sikkens, basf, so on) and go to the paint shop where you plan on buying it and get some of their spray can primer that way the paint materials match, i now sikkens does have some that match their paint materials. if you use a bunch of different kinds of primer you will have to strip it all off and re-prime the entire car or when you paint it the new paint will most likely not want to stick and lift off. remember do it right once and its alot cheaper then doing it twice and paint products are not designed to be mixed and last long. thats my two or three cents.
