gauges broken?
Old Jul 27, 2006 | 07:25 PM
espskillz's Avatar
espskillz
Default gauges broken?
ok i was wondering if there was a fuse for the gauges bc only the speed one works in my car and the 4 others inculding the gas are dead. i was thinkin if the speedometer works why not the others? i checked all the connections in the back and they are all on so am i forced to but new ones?
Old Jul 27, 2006 | 07:32 PM
Gun Jam's Avatar
Gun Jam
Default RE: gauges broken?
Im not sure if there is a fuse or not but the speedo works because its the only mechanical gauge it has a cable that runs to the trans.
Did the rest of the gauges just stop working all at once?
Gun
Old Jul 27, 2006 | 07:41 PM
espskillz's Avatar
espskillz
yea ... the car was sitting for awhile and when i started it up i realized they didnt work.
slick66stang's Avatar
slick66stang
i think all there is is a voltage regulator
Old Jul 27, 2006 | 07:48 PM
Twister's Avatar
Twister
get a copy of a owners manual
Old Jul 27, 2006 | 07:51 PM
espskillz's Avatar
espskillz
where can i get one of those at?
Old Jul 27, 2006 | 08:42 PM
slick66stang
any mustang magazine
in the use panel you have the backuplights, radio, and 1 speed washer on a 14 amp
14 amp for the heater 2.5 amp for instrument panel 7.5 for clock courtesy lights
20 amp for lighter and emergency flasher the owners manual is a little booklet that tells you the basics of your car
what you need is the ford repair manual which is $40 at mustangsunlimited.
what i would do is take the instrument panel off get a tester and with the key turned to the acc position check each wire that goes to each instrument.
Old Jul 28, 2006 | 12:25 AM
espskillz's Avatar
espskillz
is the fuse panel the box in the top left of the engine?
Old Jul 28, 2006 | 12:29 AM
slick66stang
no the fuse panel is inside the car if you look under the dash to the left you might have to remove the kick panel but there are 5 fuses in a black box. the thing you are talking about might be the heater motor its on the firewall and it sticks out and its round?
Old Jul 28, 2006 | 12:31 AM
espskillz's Avatar
espskillz
no its like a black box connected to the frame when you open the engine its to your right like almost behind the light attached to the frame.
