standard or "n" case
Old Jul 30, 2006 | 02:06 AM
thepepsifiend's Avatar
thepepsifiend
Default standard or "n" case
Hello all,
I am putting together a nine inch rear end for my 1967 mustang. I have already got the housing, and 31 spline axles. Next up is the 3rd member/center section. I am going for a 31 spline traction lock differential and probably 3.70:1 gear ratio. What I need to know is should I go for the standard case or the stronger n case. Right now I have a 289 engine in that will eventually be swapped out for a 351windsor. I don't really plan to have mre than 500 horsepower when everything is said and done. Will the standard case be allright or do I need the stronger "n"case. Also would a rebuilt traction lock work or should I go for a new one! Thanks for the help, you guys rock!
-Andrew
Old Jul 30, 2006 | 04:54 AM
baddog671's Avatar
baddog671
Default RE: standard or "n" case
a 289 isnt gonna have enough power to blow out a 9", and neither is 351W without some SERIOUS mods...
Old Jul 30, 2006 | 04:57 AM
Twister's Avatar
Twister
ORIGINAL: baddog671
wanna bet? My bro blew up a 9 inch with a STOCK 1994 GT40 Iron head engine
Old Jul 30, 2006 | 05:03 AM
baddog671's Avatar
baddog671
well maybe im wrong, but mine has been hooked up to a 351 for years
Old Jul 30, 2006 | 05:05 AM
Twister's Avatar
Twister
ORIGINAL: baddog671
9 inches don't like being cold.....
Old Jul 30, 2006 | 05:07 AM
baddog671's Avatar
baddog671
u confused me...but back to the original subject
Old Jul 30, 2006 | 05:13 AM
baddog671's Avatar
baddog671
this is your brain on drugs...
Old Jul 30, 2006 | 05:18 AM
Shifty101Easy's Avatar
Shifty101Easy
someone is FAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADED!!!!!!!!!!!!!!! !
Old Jul 30, 2006 | 05:31 AM
baddog671's Avatar
baddog671
pfff, he's from socal, it isnt even late there yet
Old Jul 30, 2006 | 05:40 AM
Twister's Avatar
Twister
I had 2 windows open and meant to post in the other....hence, I SCREWED UP!
